Being louder on lower notes sealed up
RooTxBeeR
Cone area doesn't help bandwidth lol. Only real thing I can think of is deadening, but then again, my Jeep peaked around 34hz because of the roof flex I think haha.
E34 540iT/6
My roof goes nuts on 52-56hz, so I am guessing somehwere in there for my peak. I honestly think my bandwidth has a double drop type deal. Where it is high at higher frequencies, slowly goes down until it hits my peak, slopes more off that, then goes down to my tuning, and drops straight the fuck off after that.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
That's awkward. Are you sure you're tuned to 29?
E34 540iT/6
box specs?
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
My single 15 is louder on lows sealed up, and is louder sealed up in general. I feel like its because the box I use is well over the recommended size and tuned pretty low (32hz) with a good bit of port area. I build large with intentions to shrink the box and port but I'm happy with this for my daily application so I havent made changes, yet. Now when I tried the same box on triple the power with a slightly beefier sub I shredded it within the first hour of play time. The box is pretty hard on this sub but its held up fine for about a month now and im not easy on it. With the sub only seeing 1kw clamped I feel having the box larger increases sealed output, but is risky. Over powering subs can overcome alot of hurdles too, building to be loud sealed seems to be stressful on equipment any way you look at it. Just my findings and my .02
Just for the record. Trunk car, single 15, 1kw clamped, 143db @ 46hz 140@ 32hz loses a few tenths just by cracking my window slightly. Nothing spectacular just sharing my findings. Good luck
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
2.5 cubes to be tuned so low might just be the problem. I'm at 3.33 at 29hz on my RF 15 and it still doesn't get the lowz like I want it. I'm going to two JBL 10s soon and looking to do it in the same 3.5 cubes tuned to 27.
I'm looking to play low 20s audibly and loudly. but what's weird is that I can paper trick nicely in the teens.
2007 Pacifica
I shuold be, used the Port length off of torres and deducted it properly to get the length I had to cut the wood to for the port.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
Also, I know that it doesn't it work well with the specific box, because the box is to small. But it was the same with my old subs, I built the box actually bigger than specs, and sealed up the where almost not there.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
new box time.
09 Civic EX
KDC-X395
Stock 80 Amp Alt
Big 3 In 1/0 Knu
DD-1'd 13.8v drop
I have to run sub up port up, and I dont think a .16 increase in box volume is going to make that drastic of a difference from where I am at now. I already have a new design made.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • Who's Online   0 Members, 0 Anonymous, 679 Guests (See full list)
