Home amp? Steve and his crown amps?
Hey guys, i dont post here very often, but im looking for professional advice.
I have 4 boston G5 12s that i am going to build a under the couch down fire box for, and want to hook them up in the house
The subs are single voice coil wired down to 1ohm
I do not want to do some bootleg computer PSU or drag a trickle charger and car battery into my house
I am looking for a great quality home amp that i can eventually tie into my surround sound
The crown amps steve used look awesome, but i am unsure as to what i need to look for
1) PA, DJ, or home amp, or are they the same?
2) inside the home do i need to wire the speakers back up to 4 or 2 ohm?
3) do i need an amp as strong as my car amp?
4) other than the receiver and the amp? Is anything else required?
*Most* PA/DJ amps have XLR connector inputs on the back, one for each channel. You're probably going to want to run one of those amps in bridged mono mode. So you'd likely have to adapt the low-level RCA subwoofer out from a home receiver to XLR. Might have to put it through a line driver of some kind first. That's how I had my QSC amp set up at least- it was running a single 12 in my house.
2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix |
On 6/6/2012 at 6:32 PM, 'LZTYBRN' said:
3. Don't put speakers outside the car unless you are the ice cream man.
My feedback thread
So receiver converted to xlr -> line driver -> DJ/PA amp bridged mono?
Then just find the right line driver and amp
Amp to match the specs? Maybe a 2000w rms @ 1
What would i need to use or look for in a line driver?
Any good sites or brands u would recommend? Im a boston/fosgate/diamond/dd/JL fan but as far as dj amps i would know where to start
I know i dont want the equivilant of pyle/power accoustic/boss, etc.... Or anything that is shelf filler in most pawn shops or flea markets
Well, keep in mind that you will max out at whatever your wall socket can supply. Most homes have wiring for 15a per circuit. That's after the power your TV and anything else in the room consumes.
DJ, PA amps are the same. Keep in mind they have a fan in them to cool, which will make some noise. You don't need an amp as strong as one in your car haha. I had a Crown XLS 5000 and the thing was an absolute powerhouse. But I had to re-do my wiring(not even going to go into that lol) to power the thing to it's full potential. And just FYI - drywall rattles like a MOFO and starts pulling away from the studs wit that much vibration. So you don't really want loud as much as you want to feel it. Perhaps you might consider bass shakers?
Something else to consider is most DJ amps are only 2 ohm stable, or 4 if bridged. So wiring to 1 ohm won't work ;)
You are not going to find a home or professional amplifier that will do 1 ohm stable, stereo or bridged, unless you're willing to drop a ton of money. Lowest you will ever see is 2 ohm stereo, 4 ohm bridge. With that in mind, series/parallel wiring to 4 ohm will work just fine for home use.
As for hooking it up, all you need technically is the receiver and amp, yes. There are going to be several factors that will go into what you need.
POTATO!
Good luck finding a PA amp that will go down to 1 ohm stereo much less bridged.
Wire to 4 ohms bridged or 2 ohms stereo. You're gonna spend a lot of money to get good quality power. You're better off buying a big plate amp or 2
First Gen Xterra: Always changing
DNX 690HD
RF 360.3
RF T3002
RF T4004
RF T10001bd
Silver Flute 6.5"s
Tang Band 1" Tweeters
Sundown X18 in 7cubes net tuned to 32hz
Trust me .25 Blows your Load.
