Mechman Alternators
How to calc hp draw from you alt
Amps x Volts = Watts
Watts / 745.7 (one HP) = Electrical HP Produced by the Alternator
HP x 15% Efficiency Loss = HP Loss
HP + HP Loss = Total HP Used
Example:
57A x 14.9V = 849.3 Watts
849.3 Watts / 745.7 = 1.14 HP
1.14 HP x 15% = 0.17 HP
1.14 + 0.17 = 1.31 HP Total
I found this on the net. I have no idea how accuate it is.
It actually depends on the electrical load on the alternator. When the vehicle is running with no additonal electrical load against the alternator, it will consume the same amount of HP as your stock alternator. The more amperage you draw from the charging system, the more HP is required to turn the alternator.
When putting out Max 220 amps, it will require about 5 hp to turn. The less amperage you use, the easier it is to turn.
Thanks Mechman i was wondering that my self.
*sorry to thread jack*
so a ballpark would be somewhere around 40 to 44 amps per hp??
Edited by 01VWGREENMACHINE
http://www.stevemead...f-system-build/
2001 VW GTI with a 1.8T motor
BIG 3
Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS
RF T1500-BDCP (running at 2 ohm)
RF T400.4
RF T1 D212 x2 (in ported box)
RF 1/0 TO 4 GAUGE distribution block x 2
all stinger wires
200a alternator (SINGER ALT)
RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear)
KINETIC HC 800 BATTERY (Front)
KINETIC HC 1200 BATTERY (BACK)
120ft of 1/0 stinger blue and clear matt
20ft of 4 gauge stinger blue and clear matt
30ft of 8 gauge stinger blue and clear matt
100ft of 12 gauge stinger speaker wire black
  • Who's Online   0 Members, 1 Anonymous, 1003 Guests (See full list)
