formality Posted December 8, 2012 Report Posted December 8, 2012 hi everyone i am about to install my new system and im going to have a 240 amp machman alt 2 xs power 3400s a crescendo 5500d and 2 AA mayhem 18s, now as far as wireing goes i have a 0 gauge kit and im going to get a 50 ft spool of 0 gauge so im going 2 runs of power back now my question is do i have to run the ground for the back two batterys to the negative on the main battery or can i ground them to the frame to save wire, also does it matter if its the same ground i use for my amp, thank you
Trey_Dog650 Posted December 8, 2012 Report Posted December 8, 2012 You can have a negative run. Most people gain when they do but it's not necessary. Grounding to frame is just fine. Also you can ground your amp to your back batt negative noe 13 Kia Forte Build! 07 Hyundai Accent Build ***Super Seller*** N8ball2013 And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head.
formality Posted December 9, 2012 Author Report Posted December 9, 2012 Thank you for the help you have no idea how much i appriciate it, the amp has dual inputs so can i ground them both to the back battery?
bighossf150 Posted December 9, 2012 Report Posted December 9, 2012 I have 3+ and 3- runs to the rear bank and have more wire on the way am going to do 2 more + runs from the alt to the rear batts and 2 more - runs from the rear bank to the frame. You can never have too much electrical. Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
formality Posted December 9, 2012 Author Report Posted December 9, 2012 i know im just saying for a short period of time i plan on adding additional batterys aswell iv just spent quite a bit of money and the old lady is starting to get mad, ill have to add some more later
Tarball Posted December 9, 2012 Report Posted December 9, 2012 yes ground them both to the rear batt is good. Also, don't forget to fuse both sides of your positive run from front to rear battery. (within approx 18" from your front battery AND your rears.) CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
alaskanzx5 Posted December 9, 2012 Report Posted December 9, 2012 ok, so snafu as been showing people how to correctly ground their batts alt and amps and no one is giving his advice still? go to the ce electrical section and do some reading in those threads, lots of info. http://www.stevemeadedesigns.com/board/forum/239-ce-auto-electric-supply-providing-solutions-to-all-of-your-automotive-electrical-needs/ http://www.stevemeadedesigns.com/board/topic/130212-charging-system-upgrade-kits-our-spin-on-the-big-three/ http://www.stevemeadedesigns.com/board/topic/156474-seatseat-belt-bolt-for-ground/ http://www.stevemeadedesigns.com/board/topic/155754-charging-systems-101-video-on-page-3/ http://www.stevemeadedesigns.com/board/topic/151155-the-big-3-upgrade-whats-the-real-benefit/ do the big 3, alt power wire to front batt, batt ground to fram, alt case ground to frame. from there run a power wire from front batt to back batt. ground rear batt to frame, ground amps to frame. the only time when running a ground wire from front to rear is when you frame is rusted to hell and back. the frame has been proven to be the better grounding point. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
formality Posted December 9, 2012 Author Report Posted December 9, 2012 thank your Tarball you also answered a fuse question i had! and alaska thanks a bunch for those links answered a lot!
