Abbreviations for Ohms Ω what are they?
no worries I didnt know R ohms either, I'm using the IM-SG1 right now and it says Ωc when I test a wire's impedance with different runs and I want to know what it means.
C can mean a couple things. But you cant test impedance of a wire. At least not outside of a circuit.
You probably will get an answer posting that question to D'Amore about the tool specifically.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
How do you guys type the Ohm symbol?
Try holding alt and pressing 8486 on the num pad. It doesn't work for me because I don't have a number pad on my laptop.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
Actually you can. All resistance is is the opposition to the flow of electricity. You can test the impedence of any electrical component if you have a dmm that will read very high or very low impedence. For example, I just took a 3" long piece of single strand copper wire and tested it with a fluke 45 meter and it read resistance just fine.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
X2 been wondering that. Google didnt help
Hold "Alt" and type the ASCII code using the number pad
OHM symbol = <Hold> ALT + <Numpad> 234 = Ω
http://www.asciitable.com/
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Resistance an Impedance are different things.
From Wiki pedia
Electrical impedance is the measure of the opposition that a circuit presents to the passage of a current when a voltage is applied.
The electrical resistance of an electrical element is the opposition to the passage of an electric current through that element
Ed Lester
ShowtimeSPL Host
My old Build Log
So can this tool measure DC resistance that you'd see in a wire? I don't know, never saw this tool.
Can it only measure reactive impedance as in a woofer?
Ed Lester
ShowtimeSPL Host
My old Build Log
Do you mean like mili ohms mΩ= 10-3, micro ohms µΩ= 10-6, nano ohms nΩ= 10-9 , pico ohms pΩ= 10-12
Then you have the positive side of the spectrum like kili ohms kΩ= 103 , mega ohms MΩ= 106 , giga ohms GΩ= 109 , tera ohms TΩ= 1012
Is this what you were talking about?
yeah thank you, but specifically Ωc because thats what the IM-SG1 says, I think it means closed loop?
Scion tC SQ Build
iPad mini, lots of fabrication, daily driven
Ford Explorer C Pillar Wall Build
Just a cheap car to destroy with bass :D
it can measure impedance at any frequency, when you drop the frequency to 7.3 hz it's pretty much the same as hooking up a normal dmm.
To measure the wires impedance I hook up the sgim1 to both the pos and neg wires then I connect the other end of the wire to the pos/neg so it is a closed loop.
This gives a reading and you can see it over the whole hz spectrum and if the ohms change.
http://damoreengineering.com/documents/IM-SG%20Ver.%202.pdf
Page 13-14
Scion tC SQ Build
