can a metal sub enclosure work
88pro2
More effective? Can you truly say that if you have never tried it? Only killer is cost and weight and the unknown. And with weight, you can always use aluminum. :)
10501650_10203332501847103_1859383749711
Blown
Team Gates "Alma Gates?" did a PPI build with like 64 10's in a "W" shaped 1/4" thick aluminum enclosure.
That was a SPL vehicle, 2" thick glass, pneumatic plungers with steel wedges to close the doors tight. Bagged suspension. yadda yadda. All in a bronco.
Who knows what it sounded like inside the truck though. Thing did like 176 or some craziness.
I'm thinking 3/16 plating and 1/8 for cross bracing and gussets.
box will be about 4cuft with 1 15" driver, tuned to 32.8 hz and have 2 4"x13 round ports.
Could do slot port instead. figured at 14.5x1.75x11.75 long with wood box.
I need to recalculate all measurements for thinner box walls and refigure again.
still tossing the idea around though.
Current system:
Front--Focal 165k2p components
Rear---Polk Momo 5x7 rear fill
Front amp--Rockford Fosgate Power 650 w/4" fan bridged @ 372.49w x 2(poor Focals)
Rear amp--Phoenix Gold ti400.2 @ 100w x 2
Subs--2 Image Dynamics IDQ12D2V.2 @ 1cu.ft. each sealed
Sub amps--2 Phoenix Gold ti800.1 @ 800w+ one for each woofer(poor ID's)
head unit--Alpine 7292s vintage 1990's
Eq--Alpine ERE-G180
Cd changer--Alpine 5960 6 disc also vintage 1990's
Alumapro 5fd cap
dual 1000cca batteries
ho 200amp alt.
No need to clip it because of the headroom I have with the power.
Dang spider wire broke on the Focal when glue came off the cone. Time to redo!
This is a std cab truck!!
System is changing soon!!
Looking to do a 3 way setup up front, and may double that up, to get the volume.
Also have 2 Orion HCCA15d early vintage and 3 Orion XTR2250 on hand.
Looking for Audison VRX, LRX or Zapco c2k to possibly add in.
Give it a try and see what happens!
I know someone posted a spl build up here recently that was a big large ratio fourth order for 2 xl 18s that used steel drums as the sealed chambers. It did mid 170s iirc so it can be made to work
Team NorthWestSPL
i saw a small black car on caco for sale with a box built with a 1/2 inch or so thick steel baffle on the box, but i cant remember any other details
these orphans aren't going to feast on themselves
  • 4 years later...
 This is an all metal 316ss subwoofer box. Has twin walls that are pressured separate from sub air space.  Use the valve and psi gauge with compressed air to 15 psi to eliminate wall flex. Herculiner on inside and out. Two re audio six with 2.4 cu ft on each side.
Now THAT is some cool shit!
IG @walledsonic
  • Who's Online   0 Members, 0 Anonymous, 2142 Guests (See full list)
