SPST and SPDT Relay question
do you mean like when 12v is applied to the switch part of the relay, could it stay closed for a long time until that 12v is disconnected?
Lets back track- a relay consists of two parts, the switching part that closes the circuit for the load circuit, and the load circuit. For a Normally Open relay, when 12v is applied to the switching part, the loop for the load cicuit is closed. Visa-versa for a Normally Closed relay. A SPDT relay can work the same, it just closes or opens two circuits.
Some cars (my 78 vw scirocco) has a relay that is Normally Open. But when when the car is running, the relay stays Closed the whole time, due to the 12v going through it. The relays last a long time, there's not much in there, and heat is the only thing that really ruins relays. So you cant run more amperage than what the relay can handle. Take 20% of the handling capacity and thats what you should be running through it, no more.
Stuck Open means there is nothing happening. No 12v going to it. Open means just that, open. Remember that electricity flows in somewhat of a loop; positive 12v source, into the load, out the other side as negative and back into the neg 12v. Its like a loop. So if you have a Open loop, that means there is a break in the loop. A closed loop is a completed circuit.
A relay that is Stuck Open will last forever!
why would you want a relay active at all times?
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
Posts 87a and 30 are in contact at all times unless activated then it switches from 87a to 87
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
KenC210 I think I know what you mean. If the switch part of the relay contacts are always touching. On paper it shouldnt change anything, as long as there isnt a significant amount of heat passing thru. Thats on paper. Realisically, the more a electrical circuit is passing electricity, it has a possibility to shorten its life span, the components that is, not the electricity lol. If you're thinking of making a circuit that needs 12v to keep the relay closed ALL the time (is in 24hrs), then I would just go with a normally closed relay, that way, you dont need 12v to close it. The 12v would open the loop and cut off power going to the load...
hth
if you have a relay thats using 12v to keep it active, then you are going to have battery drain, they pull around 200ma or so when they are active, there are many ways to wire up a relay, I just did 3 relay wirings today, I made the power for my deck come straight from the battery, and the power that goes through the relay for the remote turn on is right from the battery, so the factory radio turn on wire just turns on the relay, i am trying to fix some ground loop issues and noise issues :P
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
  • Who's Online   0 Members, 0 Anonymous, 557 Guests (See full list)
