Mix matching different ohm subs
FeelDaBass
I should have done a little more research before purchasing this second sub, but I now have a T0d415 and a T1d215 sub and was going to power them off of a T1500-1bdCP. Would it be bad to run these subs together on this amp? I have all 3 items listed already and in prep for making a new box. Would be wiring to 3 ohms at first. (d4 to 2 ohm, d2 to 1 ohm, series wiring). Wiring down to 1.33 somewhere in the future..
I've heard this isn't recommended but what would happen? Would it be doable if the T1 receives more power since it is 1000 watts rms? T0 is 800 rms.
Any thoughts, opinions, or advice?
'98 Chrysler Concorde LXi
Pioneer DEH-80PRS (HU/processing)
Rockford Fosgate T1652-S (components) for front
Rockford Fosgate T1693 (6x9s) for rear
Rockford Fosgate T600-4 running those
Rockford Fosgate T1500-1bdCP running a
Rockford Fosgate T1D215 15"
in a 3.1 cu ft. net tuned to 34 hz (firing in cabin)
Kicker PKD1 (0 & 4 AWG)
stock 130 amp alt for now; One yellow top Optima
Installed everything myself & built box (brother helped)
Used a DD-1 to set gains.
Build Log: http://www.stevemeadedesigns.com/board/topic/165894-first-build-accumulated-since-i-was-14/
Just Pics: http://www.stevemeadedesigns.com/board/garage/vehicle/1463-chrysler-concorde-lxi/?tab=images
Won't work!
VM-1
Pioneer DEH-80PRS
Hertz HSK 165XL
Arc Audio KS 300.2
Linear Power 1002 Full Mods
Fi Audio Q 10s
Sundown Audio Scv 3000
Big 3
XS Power D5100 Juice Box 20AH
Singer Alternator
Sky High Wire
<p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
What's the logic behind it not working? What would happen if something like that was done? I suppose this excludes using two of the same subs on one mono amp with one in a sealed box and one in a ported box..? I've thought about doing that before.
Well, you can do it. Should you do it is the question. Your money, your time.
edit:
what i mean is, at best you have to put them in separate boxes. If they go in an enclosure where they share the same airspace you will have issue like cancellation and unloading and other things. Just don't do it.
i suppose if u dont put alot of power into these ideas that they will work.... for a little while....
these amps and subs arent tested 2 work in funky setups and the consequences are random
u could be dealing with cancellation issues just 2 name 1 thing
blown outputs blown subs are a strong possibility
is it really worth it? u have some expensive stuff
if i were u and i really must have both of those subs
i would get them each their own amp
**actin bad like a kid at six flags**
Go ahead and do it. You're obviously set and fire won't start raining down the second you do.
Won't work!
Sure it will. For about 45 minutes.
If you're feeling DOWN & OUT, it's time to get UP & IN
  • Who's Online   0 Members, 0 Anonymous, 2193 Guests (See full list)
