Water Cooled Subs (Bazooka Tri Vent)
Fast Company
Thanks SnowDrifter! I think I will post some stuff up in case anybody was curious. You're absolutely right about not achieving much out of the system. But you hit the nail on the head about being unique.
i remember when Bazooka came out with those. Thats about the same time Kicker did the L7 and Xtant did the hexagons. Those things look awesome though! i saw a wall of them somewhere on the net one time, was really cool because it looked like there was no spaces between the subs cause they fit together so tightly. I agree the CHILL thing looks cool( especially with the help of some LED's placed in the right places) but for the subs i cant see any gains, but the amps that would probably help quite a bit i would think. From what i have seen Bazooka made some good quality amps also.
What i've been wondering is has anyone ever installed a refrigeration unit in their vehicle and ran cooling lines around the subs and or amplifiers? I could see this being usefull in bass drags
Some guys in Australia were cooling a sub with dry ice (solidified CO2) before runs.
Its an interesting idea but unfortunately changes the density of the air in the enclosure with how they were doing it, which not only hurt their score but is probably against the rules some way or another around these parts.
Here's a link to one of the videos:
edit
Found the video I was looking for that I had seen years ago.. this one they use Nitrious Oxide to cool the sub.
Hammerdown... 1%
these are really old. I think i was in high school at the time it came out. Im surprised you found any in working order.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Refrigeration includes a lot of condensation, not exactly ideal for electronics :(
It would be no different than water cooling your computer. On the amp side anyway. There are plenty of guides on using a window ac unit to create a super chilled setup. You use play doe etc to prevent condinsation on the mobo. Hell real extereme people use liquid nitrogen. Then there's TECs but it would all have to be custom made to fit an amp. At temps Waaaay below freezing you could prolly keep the coil cold even through the motor but.. that's all theorhetical it'd be alot of work and the amount of juice it'd take to run a mobile ac unit would detract from your amps power so it wouldn't be very efficient..
I'll have to google it though. Interesting sounding subs :P
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
Only way to keep the coil cold in traditional style motor structures is to inject cooled air into the gap, which is rather inefficient as its just like air cooling but using cooler air. Cooling the magnet will only protect the magnetic field (hot magnets lose field strength).
Hammerdown... 1%
