Need Advice on Sub
str86diesel
Ok guys..finally got a sub enclosure worked out for my truck, so I need to know which sub you guys would reccomend for some good solid beats in a .95cf sealed enclosure, down firing at the truck floor.  I was thinking about a JL 10W6V2, but the box only has 7 inches of mounting depth  :'(
Any ideas? (also budget is not a concern to me...I need beats bad.  The stock system has got to leave quickly :D)
EDIT:  According to the website, the sub can either be 8,10 or 12, but no square subs.
2k6 Dodge Ram 2500...CUMMINS POWERED - SOLD
Fi SSD10
DUAL 1 | DUAL 2
Fs: 28.3 Hz | 27.6 Hz
Re: 0.75 Ohms/coil | 1.5 Ohms/coil
Qms: 4.17 | 4.27
Qes: .48 | .44
Qts: .43 | .40
Mms: 166g | 175g
Cms: 0.19mm/N | 0.19mm/N
Sd: 310cm^2 | 310cm^2
Vas: 25.6 l | 25.6 l
Spl: 82.7dB 1W/1m | 82.7dB 1W/1m
Bl: 9.3 N/A | 14.1 N/A
Xmax: 21mm
Rms: 800W
Sealed box: .6-1 cuft
Ported box: .9-1.5 cuft @ 33Hz
Sub OD: 11.000”
Cut ID: 9.250”
Mounting depth: 6.000”
Displacement: 0.12cuft
Product code: 01910
Price: $ 179.00
*shipping is included
https://ssl.perfora.net/www.ficaraudio.com/...view.shopscript
Thanks for the reply David.  Looks like I'll be purchasing it on Monday.
Quick question on power,  the specs say 800rms.
So I've got a Hifonics BX1500D in which is supposed to do 1500x1 at 1 ohm.  so If I get that FI 10 in dual 2 ohm coils, wire it in parrellel, down to 1 ohm and put the BX1500D on it, is that gonna be to much power?  Or should I opt for the dual 1 ohm coils, wire it in series and only put 1000x1 on it?
The specs to the amp are
RMS Power @ 4 ohms : 500 Watts x 1
RMS Power @ 2 ohms : 1000 Watts x 1
RMS Power @ 1 ohms : 1500 Watts x 1
theres always the q
Q10
DUAL 1 | DUAL 2
Fs: 29.0 Hz | 26.2 Hz
Re: 0.70 Ohms/coil | 1.4 Ohms/coil
Qms: 4.80 | 5.10
Qes: .41 | .41
Qts: .38 | .38
Mms: 186g | 202g
Cms: 1.70mm/N | 1.70mm/N
Vas: 22.3 l | 22.3 l
Spl: 82.9dB 1W/1m | 82.9dB 1W/1m
Bl: 10.4 N/A | 15.1 N/A
Xmax: 27mm
Rms: 1000W
Sealed box: .2-.6 cuft
Ported box: .5-1.2 cuft @ 28-33Hz
Sub OD: 11.000”
Cut ID: 9.250”
Mounting depth: 6.500”
Product code: 01710
Price: $ 249.00
or btl
BTL10
DUAL 1 | DUAL 2
Fs: 41.2 Hz | 40.2 Hz
Re: 0.7 Ohms/coil | 1.5 Ohms/coil
Qms: 4.64 | 4.76
Qes: .21 | .20
Qts: .20 | .19
Mms: 179g | 188g
Cms: 0.83mm/N | 0.83mm/N
Vas: 11.2 l | 11.2 l
Spl: 87.5dB 1W/1m | 87.5dB 1W/1m
Bl: 17.5 N/A | 26.9 N/A
Xmax: 16mm * | 16mm *
Rms: 2000W * | 2000W *
Sealed box: N/A cuft | N/A cuft
Ported box: 0.0 cuft | 0.0 cuft
Sub OD: 11.000” | 11.000”
Cut ID: 9.250” | 9.250”
Mounting depth: 6.250” * | 6.250” *
Displacement: 0.15cuft | 0.15cuft
Product code: 00210
Price: $ 349.00
J. Jsig_253411.jpgMy CardomainFINISHED COBALT SS/SC DUAL ALTERNATOR PICS icon_nuts.gif
theres no such thing as too expensive when it comes to upgrades like that, because imo if you are gonna spend to upgrade then do it correctly rather then be a cheap ass ricer
that hifonics brutus 1500d ain't no joke bro. should push them quite well.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Is the bass gonna be clean with only 1 sub though?  I'm not looking to win any comps..but I definately wanna be able to crank it at will (after I get a new alternator that is).
  • Who's Online   0 Members, 0 Anonymous, 1500 Guests (See full list)
