Proper use of Dielectric grease?
After doing ALOT of searching I have been getting mixed messages about using dielectric grease on electrical connections. I just ran a ground to my frame with a tinned lug and it is in a spot that will get alot of weather. I have a tube of it here but am not sure if or how I should use the stuff. Do I put it in between the connection or just put it over once its bolted down? I am just not sure if it will interfere with the connection since its a non conductor. Should I use it or is there something better to stop it from corroding, Thanks!
You dont use it on open air connections, it will just wash away.
You use it on plug-style connectors.
Get a can of plastic spray (basically plasti-dip meant to be sprayed thick) or frame/truck bed liner and give it a spray. Will never corrode..
Hammerdown... 1%
Ok, Thanks. That platidip stuff can be removed if I recall? in case I ever had to swap the wire.
EDIT: just seen plastidip liquid electrical tape lol, I wonde rif that will do the same thing
I always give my frame grounds a coat of terminal protectant.
Kenwood KIV-701
Crescendo BC2000D
DC Audio lvl3 w/ lvl4 upgrade, 18''
6ft^3 @ 27hz
MBquart ONX 4.125
(2) PWX 6.5
(2) PWX 8
(2) FT1
300amp Singer with VCM @14.5
Optima YT & D1200
My Build Log
every company has their niche market. hifonics has successfully captured the average ignorant teenage boy.
Dont trip.. Ive never won anything in my life. Spite a 10lb cock and a bucket of balls at birth,......
Yeah.. like i said, nothing in my life. :shrug: meh, im cool with it, fuck it.
I do the same. Painting would probably last longer, but I think the red battery terminal spray works pretty good. Better than nothing.
Cool, how often do you have to re-apply it? You have any links to the stuff so I know what to look for
This is the stuff I use. http://www.autozone.com/autozone/accessories/CRC-Battery-terminal-protector/_/N-25tb?itemIdentifier=55918_0_0_
It stays on pretty good under the engine bay, but the more exposed can be re-applied every so often. Cant really say how often. I do it after everything is bolted up as well.
I hate that red spray on stuff, never works for me..
Hammerdown... 1%
Does it just come off easy? Or do you get corrosion? It's definitely not permanent, but I think its easy to just spray on there every once in a while. Ive been lucky and never had any corrosion on my truck even after all the crap I put it through.
  • Who's Online   0 Members, 0 Anonymous, 1250 Guests (See full list)
