CoritaAlterado Posted January 18, 2013 Report Posted January 18, 2013 I found this read interesting, maybe it can help you decide: http://www.knukonceptz.com/assets/pdf/pasmagwiretest.pdf
CNF Kevosinn Posted January 18, 2013 Report Posted January 18, 2013 thanks for sharing that! *** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ ) "kevosinn's" astro van 8 custom Sundown Zv4 18's 4 Sundown scv 6000's CNF Distribution CNC parts Skyhigh wire some batteries SMD Meters and tools used on the installhttp://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/ 16,000 watt walled silverado build.http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/ 8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60TEAM CNF Distribution
CommonSyns Posted January 18, 2013 Author Report Posted January 18, 2013 How long are these runs going to be? I'd only use CCA if they're less than about 15 feet. At least 2 runs from the front battery to the rear battery. Probably some where in the range of 25' to 30'. Also why not is it that bad? sounds like a cool build! post up a build log once you get it going Oh, Trust me I will. I found this read interesting, maybe it can help you decide: http://www.knukoncep...magwiretest.pdf Looks like an interesting read. I will definitely read this. Skar Audio SDR 10" x2 (Sealed Box) Skar Audio 1500.1D (1 Ohm) x1 Skar Audio TX525c (Front with dash tweeter) x1 Kenwood Excelon KFC-X173 (Rear Coax) x1 JL Audio 360.4 (Mids & Highs Amp) x1 DEH80-PRS XS Power d3400 Singer Alternator 275A 98 Jeep TJ 4.0 5 Speed
Watch the bass Posted January 18, 2013 Report Posted January 18, 2013 what wire are you getting? I am buying from AudioTechnix. Either CCA or OFC 1/0 awg. More as in more runs from front to back. A single run can only carry so much current over a certain length. So like you know 1 run of 1/0 CCA cannot carry the same amount of current as 1 run of 1/0 ofc. But 2 runs if 1/0 CCA wire can out perform 1 run of 1/0 ofc So I would need 4 runs of CCA 1/0 awg? 2 positive and 2 negative. I am getting 2-3 batteries for the back. Do I still need 2 runs of 1/0? Rule by thump OFC can carry per run 300 amps CCA 250 amp´s. 4.5 K watt amp draw´s 450 amp´s, so you need 2 runs pos and 2 runs neg. A other thing is OFC stay´s cooler than CCA, there is a thread in the sonic or XS section with vid, sorry didn´t remember exactly where. "in the abundance of water, the fool is thirsty" Bob Marley
will77530 Posted January 18, 2013 Report Posted January 18, 2013 i didnt feel like reading what other ppl said so here we go cca =250 amps ofc=300 amps theres your big difference and thats how you figure out how many runs your going to need just some basic math you can do it i believe in you...also you dont have to do runs of ground to the battery it has been proven to not make a difference snafu did a video about it
CommonSyns Posted January 18, 2013 Author Report Posted January 18, 2013 2 runs front to back should be fine, but what about the runs to the amp itself? I assume they'll be relatively short since you have batts in the back Sounds good, I got a good deal on this CCA 1/0 awg wire. I think that I can just run the amplifier positive's straight to the batteries that I will have in the back. Should be no longer than 3 feet from the battery to the amplifier. i didnt feel like reading what other ppl said so here we go cca =250 amps ofc=300 amps theres your big difference and thats how you figure out how many runs your going to need just some basic math you can do it i believe in you...also you dont have to do runs of ground to the battery it has been proven to not make a difference snafu did a video about it So I don't have to make another 2 runs to the rear batteries ground? That's good to know less wire to use and more for other things. Skar Audio SDR 10" x2 (Sealed Box) Skar Audio 1500.1D (1 Ohm) x1 Skar Audio TX525c (Front with dash tweeter) x1 Kenwood Excelon KFC-X173 (Rear Coax) x1 JL Audio 360.4 (Mids & Highs Amp) x1 DEH80-PRS XS Power d3400 Singer Alternator 275A 98 Jeep TJ 4.0 5 Speed
CommonSyns Posted January 18, 2013 Author Report Posted January 18, 2013 what wire are you getting? I am buying from AudioTechnix. Either CCA or OFC 1/0 awg. More as in more runs from front to back. A single run can only carry so much current over a certain length. So like you know 1 run of 1/0 CCA cannot carry the same amount of current as 1 run of 1/0 ofc. But 2 runs if 1/0 CCA wire can out perform 1 run of 1/0 ofc So I would need 4 runs of CCA 1/0 awg? 2 positive and 2 negative. I am getting 2-3 batteries for the back. Do I still need 2 runs of 1/0? Rule by thump OFC can carry per run 300 amps CCA 250 amp´s. 4.5 K watt amp draw´s 450 amp´s, so you need 2 runs pos and 2 runs neg. A other thing is OFC stay´s cooler than CCA, there is a thread in the sonic or XS section with vid, sorry didn´t remember exactly where. So I do still need the 2 runs of 1/0 awg in my Jeep. I did not know that OFC stays cooler than CCA. Is the CCA heat going to be a problem? Skar Audio SDR 10" x2 (Sealed Box) Skar Audio 1500.1D (1 Ohm) x1 Skar Audio TX525c (Front with dash tweeter) x1 Kenwood Excelon KFC-X173 (Rear Coax) x1 JL Audio 360.4 (Mids & Highs Amp) x1 DEH80-PRS XS Power d3400 Singer Alternator 275A 98 Jeep TJ 4.0 5 Speed
