Inverted hitting sub? (wiring, not actually inverting the sub)
naenae
Sub is mounted normal, but when the sub hits it is inverted? if that helps,
And also, how would this sound: 4 subs total, 2 are hitting normally, and the other 2 are (wired?) invertedly. so i could have a cool looking set up? if that sounds right...
(Noob btw...)
don't do this....they would cancel each other out, be trying to play against each other
Mount them normally and wire them all in phase
Team Flex Issues
i feel like if i try to answer this question its just going to confuse my self but fuck it lets give it a try.........if all your subs are mounted normal or mounted inverted the are wired normal...if 2 subs are mounted normal and two are inverted the two that are iverted you need to reverse the wiring to keep everything in phase if you dont do this youll hvae cancellation and it will sound like ass
(Noob btw...)
I thought this would make them work together? kinda like this...
(Noob btw...)
it wouldnt be nearly as loud....
all of the subs need to be firing in the same direction to create pressure and make bass.
if 2 are firing out and the other 2 firing in the not near as much pressure is being made...
(Noob btw...)
YES! this guys got it... so i would be losing bass? so to say...
  • Who's Online   0 Members, 0 Anonymous, 825 Guests (See full list)
