CommonSyns Posted January 25, 2013 Report Posted January 25, 2013 I'm getting a new system which consists of AudioTechnix 1/0 awg CCA wire in two 50' spools one blue one white, two Skar Audio ZVX's powered by a Skar Audio 4500.1D at 1 ohm. And later on a single Skar Audio 125.4 and two sets of VXI component speakers, a High Output Singer Alternator 250A, and the "The Big 3 in OFC Audiotechnix 1/0 awg wire, with 3 rear batteries the Deka Intimadator. My question: How many runs of runs of 1/0 awg do I need for the front to the rear batteries? This is going in a 2000 Jeep Grand Cherokee Laredo. Skar Audio SDR 10" x2 (Sealed Box) Skar Audio 1500.1D (1 Ohm) x1 Skar Audio TX525c (Front with dash tweeter) x1 Kenwood Excelon KFC-X173 (Rear Coax) x1 JL Audio 360.4 (Mids & Highs Amp) x1 DEH80-PRS XS Power d3400 Singer Alternator 275A 98 Jeep TJ 4.0 5 Speed
OrionStang Posted January 25, 2013 Report Posted January 25, 2013 2 pos and 2 neg should be fine. SMD Super Seller My Feedback Thread
Kyblack76 Posted January 25, 2013 Report Posted January 25, 2013 http://www.stevemead...-video-on-pg-5/ Read there for some ground FRONT TO BACK questions. Also,.. You should scope out Ce Auto, a partner here on the site.. And you will get a discount because your a SMD member... http://www.ceautoelectricsupply.com/ Has it all. And top tier gear as well... cheers and great luck SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
CommonSyns Posted January 25, 2013 Author Report Posted January 25, 2013 2 pos and 2 neg should be fine. 2 runs of CCA will be good for my install? My local car audio store told me that I might not need to run a negative from front to back is this true? thank you for your help http://www.stevemead...-video-on-pg-5/ Read there for some ground FRONT TO BACK questions. Also,.. You should scope out Ce Auto, a partner here on the site.. And you will get a discount because your a SMD member... http://www.ceautoelectricsupply.com/ Has it all. And top tier gear as well... cheers and great luck I will check that link and I will also look into Ce Auto. Thank you for your help Skar Audio SDR 10" x2 (Sealed Box) Skar Audio 1500.1D (1 Ohm) x1 Skar Audio TX525c (Front with dash tweeter) x1 Kenwood Excelon KFC-X173 (Rear Coax) x1 JL Audio 360.4 (Mids & Highs Amp) x1 DEH80-PRS XS Power d3400 Singer Alternator 275A 98 Jeep TJ 4.0 5 Speed
Kyblack76 Posted January 25, 2013 Report Posted January 25, 2013 2 pos and 2 neg should be fine. 2 runs of CCA will be good for my install? My local car audio store told me that I might not need to run a negative from front to back is this true? thank you for your help http://www.stevemead...-video-on-pg-5/ Read there for some ground FRONT TO BACK questions. Also,.. You should scope out Ce Auto, a partner here on the site.. And you will get a discount because your a SMD member... http://www.ceautoelectricsupply.com/ Has it all. And top tier gear as well... cheers and great luck I will check that link and I will also look into Ce Auto. Thank you for your help No worries. Hope it helped. Good luck. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
8ight Posted January 25, 2013 Report Posted January 25, 2013 2 runs of CCA will be good for my install? My local car audio store told me that I might not need to run a negative from front to back is this true? thank you for your help While not necessarily wrong with the wattage you are running I would recommend strongly that you have dedicated ground runs to the front of your vehicle. As far as how many runs is concerned a good call is always as many as you can afford, your electrical system can never be too good. I'm gonna hate
Carbon Posted January 25, 2013 Report Posted January 25, 2013 Im way overkilling my electrical before I start putting in the thirsty amps.
Kyblack76 Posted January 25, 2013 Report Posted January 25, 2013 Remember what Tony D and Tony C both proved in their FRONT TO REAR testing ?!?!?!?........... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
8ight Posted January 25, 2013 Report Posted January 25, 2013 Im way overkilling my electrical before I start putting in the thirsty amps. That way you won't have to smell them! I'm gonna hate
Carbon Posted January 25, 2013 Report Posted January 25, 2013 Im way overkilling my electrical before I start putting in the thirsty amps. That way you won't have to smell them! True dat! Heres a pic of the last guy who underpowered his HIFI amp!
