DC Sound Lab
2 x LVL3 15" D2s or D4s with DC 3.5K amp
Hello!
I have plans for purchasing two LVL 3 15" and a DC 3.5K amp, should i go for subs with dual 2 ohm coils or dual 4 ohm coils?
With dual 4 ohm i get to run the amp in 1 ohm and with dual 2 ohm it get's down to 0.5 in the theory. Is 0.5 the way to go because of the impraise?
I will mostly play music but i wan't to be able to go loud also.
The car is a BMW E39 540i/6 Touring.
Any thoughts?
BMW E39 540i/6 Touring Bassrace competition car with Impact and DC Audio.
get two D1 subs and you can wire them to 1ohm.
edit: ok i just checked dc's website because I didn't know if they made d4 lvl 3 subs, but they do so yes you can get two d4's and wire to 1ohm. You can also wire at 1 ohm with two d1's. And NO don't wire at .5
Edited by youngsticky
I know what it takes to run an amp at .5, but i don't have any experience loading DC amps at .5 so i wanted to hear your thoughts.
So will the 3.5K amp and 2 x lvl3 15" d4s be good or do i need to get an 5.0K?
Edited by Johan Gustavsson
If you are wanting to power 2 Level 3s with the 3.5k, I would go with Dual 1 ohm subs and wire to 1 ohm.(I would also add the Level 4 upgrade to the Level 3 subs).
If you wanted to drop down to .5 ohm(this will void your warranty and requires a stronger electrical system to properly supply the amp), then I would run a pair of Level 4s.
  • Who's Online   2 Members, 0 Anonymous, 1155 Guests (See full list)
