Mobileaudio25 Posted January 29, 2013 Report Posted January 29, 2013 I'm building a sealed firing forward set up for my ported DD3512's and I was wondering how effective sound deadening would be if it is at all... I have one complete layer in the whole trunk. I'm running 2500w rms
will77530 Posted January 29, 2013 Report Posted January 29, 2013 i dont get what your doing...raplacing a ported box with a sealed box?
Mobileaudio25 Posted January 29, 2013 Author Report Posted January 29, 2013 no i have a ported box. Im installing a sealed firing forward enclosure... and enclosure is built around your box so that all of the sound is directed into the cabin. Am I using the incorrect name for this type of install?
Guest Posted January 29, 2013 Report Posted January 29, 2013 no i have a ported box. Im installing a sealed firing forward enclosure... and enclosure is built around your box so that all of the sound is directed into the cabin. Am I using the incorrect name for this type of install? yes you are using the correct terminology. sometimes people get confused because of the sealed part lol. sometimes people use "firing forward sealed off"
ToNasty Posted January 29, 2013 Report Posted January 29, 2013 Your sealing off the trunk so it can go through the rear into the cabin? - ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
Mobileaudio25 Posted January 29, 2013 Author Report Posted January 29, 2013 from the rear (trunk) into the cabin (front) - of the car.
notorious97200 Posted January 29, 2013 Report Posted January 29, 2013 If it's sealed from the trunk you will not have any vibration in the trunk, so no sound deadening should be needed. and you already have one layer, so it's good. If you're talking about the doors, roof,... it's another problem, and you may need some. Whatever system your running. Just my 02 cts ! black BMW X1 2.0 l 192 hp OEM head unit, Amplifiers : Audison AP 8.9 with integrated DSP and Ampere Audio 1200. Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats. 2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
IH8PunkRok Posted January 29, 2013 Report Posted January 29, 2013 yeah once you seal off the trunk there are almost no vibrations at all i had none and only "sealed" it with duct tape -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
