jessdabest77 Posted January 30, 2013 Report Posted January 30, 2013 Anyone know what's the best type/brand of solder to use on welding cable?Going on copper terminals and maybe the regular ring one's.
Tarball Posted January 30, 2013 Report Posted January 30, 2013 Silver solder - dont forget the flux. http://www.homedepot.com/buy/oatey-safe-flo-8-oz-lead-free-silver-solder-290242.html CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
cloud77 Posted January 30, 2013 Report Posted January 30, 2013 Silver solder - dont forget the flux. correct. If you go to home depot its solder for electrical 2004 Grand Prix GT (2) 12" RE XXXs (04/05 XBL^2) 5 cu. ft tuned @ 35 Hz MMATS HD4000.05 MMATS SQ4100 Infinity Kappa components Juice Box black cherry Duralast platinum group 34 1/0 KNU OFC, 2/0 welding Singer 250A
jessdabest77 Posted January 30, 2013 Author Report Posted January 30, 2013 ok,I know there's different type's
cloud77 Posted January 30, 2013 Report Posted January 30, 2013 yah its bright silver. 2004 Grand Prix GT (2) 12" RE XXXs (04/05 XBL^2) 5 cu. ft tuned @ 35 Hz MMATS HD4000.05 MMATS SQ4100 Infinity Kappa components Juice Box black cherry Duralast platinum group 34 1/0 KNU OFC, 2/0 welding Singer 250A
CW06Silvy Posted January 30, 2013 Report Posted January 30, 2013 Yes, silver solder is what you want. You will also need a bunch of paper towels and isopropyl alcohol (to clean the solder before you actually use it). And get a good quality flux, dont cheap out.. Also, be sure to clean the remaining flux off the joint with the alcohol (I also use a small paintbrush) after you are done. 2006 Silverado Ext. Cab 6-15" SSA ZCONS 4th Order Blow-Through Pioneer AVH-P4200dvd American Bass VFL 1100.1 12 volt 6 C&D Batteries 2-350A Singer Alternators and Stock Alt DC Power Triple Alt Kit MLA Module 3 Runs of 1/0 2 Sets of Boston Acoustics 6.5 Pro Components Boston Acoustics 2-channel Lots of Sound Deadener ....Build still in Progress...
cloud77 Posted January 30, 2013 Report Posted January 30, 2013 Yes, silver solder is what you want. You will also need a bunch of paper towels and isopropyl alcohol (to clean the solder before you actually use it). And get a good quality flux, dont cheap out.. Also, be sure to clean the remaining flux off the joint with the alcohol (I also use a small paintbrush) after you are done. Does this help it stick and hold better? 2004 Grand Prix GT (2) 12" RE XXXs (04/05 XBL^2) 5 cu. ft tuned @ 35 Hz MMATS HD4000.05 MMATS SQ4100 Infinity Kappa components Juice Box black cherry Duralast platinum group 34 1/0 KNU OFC, 2/0 welding Singer 250A
CW06Silvy Posted January 30, 2013 Report Posted January 30, 2013 No, actually if you clean the solder before you use it you will find that it generally is much dirtier than you think. The point of soldering is to join the wire to the connector and eliminate oxygen for corrrosion for a better joint. If you leave the dirt on the solder that is exactly what you are putting in the joint. Also, flux can act as a corrosive on the solder and if you dont clean it off it can cause problems down the road. I have found that by cleaning the solder it is slightly easier to work with. 2006 Silverado Ext. Cab 6-15" SSA ZCONS 4th Order Blow-Through Pioneer AVH-P4200dvd American Bass VFL 1100.1 12 volt 6 C&D Batteries 2-350A Singer Alternators and Stock Alt DC Power Triple Alt Kit MLA Module 3 Runs of 1/0 2 Sets of Boston Acoustics 6.5 Pro Components Boston Acoustics 2-channel Lots of Sound Deadener ....Build still in Progress...
DTA HONDA Posted January 30, 2013 Report Posted January 30, 2013 I use kester solder every day. good stuff 2012 Ram 3500. HTT 2nd Gen manifold Swap, HTT s465 Turbo, FASS 150, 6" S&B Intake, 5" TBE, RaceMe programmer, 8 inch tip (dumped over axle) 20x12s on 35s, 6 inch lift, Color match & haloed headlights, 30" lightbar flush mounted in bumper. 2 Sundown audio SD-2 12s and a Soundqubed Q1-1200d amp. 2000 s10 xtreme *SOLD*
