F150 big 3
Alright and last couple questions. Should I just add onto the stock wire or replace it? And do and of you know where the block to chassis is located on an f150?
03 Ford f150
2 Sa8 v2s
Ap 1800d...
Stinger 0 Guage
CA Auto/ Electric Big 3
Xs power d680 in parallel with new group 65 stocker
Soon to come another d680
Rockford Punch 6x8 3 ways in the front, Rockford Punch Pro 6.5s in the back
Soon to come Pioneers all around
Focal Solid 4 Speaker Amp
Kenwood KDC-X896
Memphis Line Driver
My build log: http://www.stevemeadedesigns.com/board/topic/160368-03-f150-king-ranch/
Youtube: https://www.youtube.com/user/LabAudio502?feature=mhee
I dont have a alt-bat fuse either.
I ADDED to my stock cables.
No idea on a F-150.!?!?... Can't be hard to find though.
Your making a good choice man. You'll shit a Twinkie when you see all the care,thought and quality Tony puts into his gear.
And the most detailed instructions to work with, its like he is right there helpin ya.
Best of luck, and show us pics!
Alright guys I'm going to order the kit later on and hopefully get a little bit of a deal. Thanks! I will post some pics when done.
03 Ford f150
2 Sa8 v2s
Ap 1800d...
Stinger 0 Guage
Kenwood KDC-X896
Memphis Line Driver
Is there already a ground wire running from the engine to chassis? Or is this something that I will completely adding. I understand that the neg from the battery runs straight to my body. Them the pos to alt is simple. Bu that third wire from engine to chassis... Where is it?
03 Ford f150
2 Sa8 v2s
Ap 1800d...
Stinger 0 Guage
Kenwood KDC-X896
Memphis Line Driver
T.A.G. - our kits include all the hardware required to connect your stock wiring to the upgraded clamps and require no special tools to do so. I have gone out of my way to include all of the components you'll need to install the kit successfully without needing a single thing other than common hand tools.
The purpose of the fuse on the charge lead is to protect on-board electrical components in the event of voltage run-away. This can occur if the voltage regulator in the alternator fails. If that happens, it is not uncommon to see an alternator put out 70-80 volts and that can certainly cause damage. In the 20 plus years I've been at this, I've never personally seen that happen but I do educate folks about the possibility of this. If you look closely at the stock charge lead on your truck, it likely has a fusible link (or pair of them) - this is exactly what that is for.
Hit me up when you're ready and yes, I'll work you a deal.
Tony Candela - SMD Sales & Marketing
Email me at [email protected] to learn about becoming an SMD Partner!
That is really cool. I will give you all a call here in a few days gotta wait for some extra funds that I'm expecting.
03 Ford f150
2 Sa8 v2s
Ap 1800d...
Stinger 0 Guage
Kenwood KDC-X896
Memphis Line Driver
  • Who's Online   0 Members, 0 Anonymous, 1008 Guests (See full list)
