Guest Posted February 3, 2013 Report Posted February 3, 2013 An alt spinning backwards will have cooling issues. this is true. is there a way that mechman or whoever can just mount the fan backwards?
OrionStang Posted February 3, 2013 Author Report Posted February 3, 2013 Doesn't work that way Kranny. It would have to be machined with the fins reversed, talk about money. SMD Super Seller My Feedback Thread
E a r t h Posted February 3, 2013 Report Posted February 3, 2013 Ken, what you would be attempting to do with your original post , is re-invent the wheel. You could always go with a 370xp. The only concern I would have with that would be belt slip, which you may, or may not get lucky with. Wouldn't duals have greater idle performance than a 370? Ken, what you would be attempting to do with your original post , is re-invent the wheel. You could always go with a 370xp. The only concern I would have with that would be belt slip, which you may, or may not get lucky with. Wouldn't duals have greater idle performance than a 370? Yes, unless two inferior units were used, but back to your 1st post. Your sketch resembles what would require you to re-engineer the alternator. Essentially mounting another unit facing rearward would do the same thing. Only difference would be direction of rotor rotation.
OrionStang Posted February 3, 2013 Author Report Posted February 3, 2013 Okay, with bith units facing the same direction, the only hurdle is how to attach the center shafts. Look at the pics I took of my stock alt. Somehow attach a rod from the pulley of unit A to the rear shaft of unit B. Or am I missing something? SMD Super Seller My Feedback Thread
sphinxbccp Posted February 3, 2013 Report Posted February 3, 2013 Could you extend the rear of the shaft of the secondary alt and attach a pulley to that? That way the cooling doesn't change? Build log: Click Feedback: http://www.stevemead...xbccp-feedback/ 03 Chevy Blazer - IPad Air 2 - ALPINE Head Unit - 4 DC XL 18s - 2 DC 3.5k - ALPINE TYPE R 5.25 COMP - 3 ALPINE TYPE R 6.5 COMPs - DC 175.4 - DC HO Alt - D3400 - 4 XP3000s - KNU 0ga - 60 SqFt Damp Pro Lots more...
Omega5002 Posted February 3, 2013 Report Posted February 3, 2013 Is there no room to mount it next to the main alt? 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
OrionStang Posted February 3, 2013 Author Report Posted February 3, 2013 Thats a V6. SMD Super Seller My Feedback Thread
Omega5002 Posted February 3, 2013 Report Posted February 3, 2013 Nevermind then, forgot you had a GT 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
OrionStang Posted February 3, 2013 Author Report Posted February 3, 2013 Mine is tucked away nice and tight under the throttle body. You can barely see it here, same color as the car. SMD Super Seller My Feedback Thread
I.V Posted February 3, 2013 Report Posted February 3, 2013 interesting ,good luck 06 Trailblazer ss2 Team shok industries tsx 18sPhoenix Gold ''THE ONE''2 Phoenix gold 800.44 crescendo mp6.2 crescendo mp8bass processor Dc power 270xp 150ft 1/0 ofc sky high cable1 juicebox lithium 0.5kwh 14v/40ahkenwood dnx8120BCAE1.com YouTube channel : REaudioxxx1build log: http://www.stevemeadedesigns.com/board/topic/160106-trailblazer-ss-xxx/
