Mechman Alternators
02 Chev Blazer Dual alt kit guys??
you wouldnt have to remove the ac unless you wanted to put the alt there instead. if you search i know joe has pics posted someplace here or PM him, He can probably help you out a lot or even maybe make you something.
but like i said the front of your engine is the same as mine, so you have numerous options, just getting the clearance is going to be the hard part, but it has been done multiple times :D
Thanks B,
Moving shit is fine. Even losing the AC.
Im already rolling with some ideas... GRACIAS
losing the AC? In times like these? Just roll down your windows and you'll freeze up, screw that AC! But summer time? Ahh, as long as you don't mind bugs flyin in, you be good with the windows down. Think our areas are roughly the same degree wise, i'm good with windows down.
Sheena = pedobear
It's true- we developed a complete triple alternator setup for 96-2000 vortex 5.7 trucks after literally hundreds of requests, and we hardly sell any at all. People think it just some simple steel bracket that should cost $20, but a lot more goes into it than that. Idler pulleys, belt, laser cut pieces, welding, manual tensioner, it takes a lot of stuff to make a multiple alternator setup work properly and retain the AC. We even had to so so far as using compact 6 phase units to make them fit properly.
You could try our triple kit on your 4.3l blazer, but I can't guarantee it will fit. The 5.7 engine is similar, but the throttle cable and engine compartment are different on the s10 blazer.
Pm or call us for more details
If you want to lose the ac its a simple fix to run dual alts on the 4.3.. The bracket can be found for 100bucks
Team Devastation Mixed Martial ArtsMachado Brazilian JiujitsuOnce I lock it on there's no escape I don't train to make you tap, I train to tear your arm, leg, or head off. Its your job to tap before I can do that -Pain is only weakness leaving the body, its kill or be killed and only the strong survive...Rockford FosgateDigital DesignsFi Car AudioCrossfire Car Audio
Can you email a link to the "$100 bracket" to [email protected]
  • Who's Online   0 Members, 0 Anonymous, 644 Guests (See full list)
