Silverado Sub box help torres
KenC210
are you restricted on space?....I personally wouldn't want to run my port only 1.75inch wide...might get some noise from that narrow of a port
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
Try it with some 1/2 inch wood, like birch. Makes stuff a whole lot easier. 2 3 inch or maybe 4 inch PVC ports too. You'll get some port noise out of that long narrow port.
try these measurements
17.5x60x5.5 & 7
1 6inch aeroport 25.5inches long
gets you to 2.00cubes @ 35.65hz
*edit for aero
Alpine CDE-hd148bt
Alpine PKG-RSE2
Kicker KX350.4
DC Audio 1.2k
A single 6" aero would perform great there and would increase your net a bit.
where are you gonna fire that 6" port though?
OP, what year is this Silverado? The reason Im asking is because you don't have that much height unless you step the box out from the back wall(if it's a 99-06)
yes it is a single cab and the box is for a bigger guy and needs the seat so far back. Was thinking subs on passenger side and port driver side.
It's louder with the subs driver side, port firing into B-pillar
I've built quite a few boxes for the 99-06 Sierra/Silvys
If it were me, I would leave 4 inches past the end of the box UNobstructed and fire a couple of 4" PVC ports right at the pillar. He will be pleasantly surprised with the output from two entry level 10s
I will have to find out... I believe it is a 98.
And subs driver side port to passenger side is best?
  • Who's Online   0 Members, 0 Anonymous, 1172 Guests (See full list)
