Peyton Cole Posted February 15, 2013 Report Posted February 15, 2013 Car xg350 Alternator 120amps Battery stock 30farard cap(probably will get blasted for this) Pioneer hu Jvc 4 channel amp Just purchased a brutus2400watt amp and 2aundown15s Do I need a extra battery if so what kind and do I need to charge it before having it installed?? Team CNGraphix 2013 sonata Dc power 320 alt 3 kinetik 3 shuriken All knue and sky high wiring Dd m3b x2 Rockford 1000-4 2 fi sp4 18 4 vo 6.5 4 nendo pwx8 6soundqubed tweets 2 b1 tweets Pioneer avh4500 hu
teamace24 Posted February 16, 2013 Report Posted February 16, 2013 0 gauge wire, upgrade stock battery and add a second battery. Also the big 3. Battery could be like a Die hard platinum and such or look at the hot deal sections for that 90 buck one. 1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
ToNasty Posted February 16, 2013 Report Posted February 16, 2013 dont use the cap. its a waste ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
zayres29 Posted February 16, 2013 Report Posted February 16, 2013 Replace the cap with the bat you are planning and you should be good Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
P4killer_ Posted February 16, 2013 Report Posted February 16, 2013 Your gonna want a second agm battery.. for 2400+ w.. I bet the voltage drop on a single k1400 would be pretty nasty.. Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
Watch the bass Posted February 16, 2013 Report Posted February 16, 2013 Correction cap is only 1 farad and shop recommends putting it on the 4 chan only Is it ok if they are 2 dif batteries You can use diffrent batt´s so long there are same technic and secondarly on the same place. Don´t mix AGM batt´s with lead acid, if you have to lead-acid please only under the hood, incase of the acrid fumes. Ditch the cap, a cap is only usefull if your electrical system is a solid rock. http://www.stevemeadedesigns.com/board/topic/144556-dont-seem-like-a-bad-deal/ the 90 buck batt offer. If your currently batt isn´t a AGM batt., gett 3 of them 1 under the hood 2 in the trunk. "in the abundance of water, the fool is thirsty" Bob Marley
WastedTalent Posted February 16, 2013 Report Posted February 16, 2013 Your gonna want a second agm battery.. for 2400+ w.. I bet the voltage drop on a single k1400 would be pretty nasty.. that's a for sure. I have a 1200 and 800 I believe from kinetik. only runnin a 1500bdcp from tf.. big drop. Need to do all the upgrades though. lol. big 3, h/o alt, etc. Sheena = pedobear
