Misc. Sealed off trunk - '01Stratus *Gutted*
This is a great build so far! Patience definitely goes a long way when doing stuff like this. Keep it up!
2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant
- Fi and Crescendo - Stock Bose System
- http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota
136.4 Sealed @ 29hz
137.0 Drivers window open @ 26hz
Well I knew that if I was to seal off and secure the box to the car that I would have HUGE issues spraying glue onto the sides of the box. So I did that first.
Layed down news paper to cut down on overspray.
Marked on each side of box where the side panels ended. Then transfered that to the carpet. This way I would know where to stop spraying the glue so that I wouldn't have issues putting the side panel back on.
Left side
Right
I then wanted to put weather striping around where the box was going to be touching. I then realized it was going to raise the box too much. LOL
Hmm, the car jack was useful for something ;) Jacked up the box to put the weather stripping on, which was ripped off 5 mins later.
Put masking tape down for the foam.
Put the sides back on and put some of the foam rod caulking around the edges.
I used lock washers under the bolts. First time using them and holy crap! I stripped out a screw and tried to back it out. Dug into the sheet metal like no other.
foam foam foam foam :)
I still have some touching up to do. But that was one bottle used. Will have to get another and fill in the bit up top and misc holes in the deck.
Started to trace the cardboard onto mdf. I tacked it down with a staple gun so I wouldn't have to fight it lol.
Mad freestyling
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
Will be picking up the last of the supplies tomorrow :) rubber washers, ziptie mounts and more foamy goodness
Exhausted. Worked right after school till 11, no breaks lol.. snackin now
Worked on the big 3. Wondering what the hell I was smoking when I planned out where the wires were going. I eventually figured it out.
Stock next to D925. The XS power weighs a good 5 pounds more than stock. It was rather impressive considering how much smaller it is.
Lame stock terminal is lame. Snipped that off and soldered 4ga ring terminals onto 8ga wire(stock) I used the trick that I used when doing my 1/0 earlier.
Had to have my Dad hold the wire in pliers while I soldered it.
Stock battery is still useful after all. I made a battery rack so the front battery would slide around, ground out and blow up.
I didn't want my fuse holder to move around that much, so I made a mount for it somewhat. I dado-ed (i believe its the right term) the wood to the correct depth.
I also shaved down the foam from yesterday. I then filled in all the other misc. holes. Good thing I did because a few I didn't realize went down into to trunk. It is now 98% sealed off.
This is where I will be grounding at in the rear.
Kidding. It is just the hole for when I drill through tomorrow. I needed a pilot hole
Here is the hole on the outside, and the bolt I will be grounding to.
And these are what took so damn long. Trying to get them to fit just right. They still don't fit, but I wanted to get 80% of the cutting done because I am tired of mdf dust being where mdf dust shouldn't be.
More plz! Your build is getting awesome er
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
sweet O_O
tuned in.
If you have any questions relating to nutrition, lifting, or health in general, feel free to give me a PM and I will give you straight forward advice with no BS involved.
Nice build man!!!
2010 Kia Forte Koup (Slow Build)
2 Sundown SCV-3000D
2 DC XL M1 with PSI recones
Focal R-165s2 on Orion 4800-HP
Kenwood KDC-X798
Knukonceptz OFC 1/0
Audiotechnix,Fatmat and Q-mat Deadener
XS power D3400 up front 3 D3100s power in trunk
Stock 110 amp alt
2013 Scion TC
2 Dc lvl 3s with xl coils on Soundqubed 2200
Sundown components
AA 50.2 for components
Pioneer FH-X700BT
Knukonceptz OFC 1/0
XS Power D3100 up front D925 in back
Mechman 240 alt
http://www.stevemeadedesigns.com/board/topic/189911-2013-scion-tc-build/ <Scion TC Build
http://www.stevemeadedesigns.com/board/topic/174094-jskiles-forte-koup/ <Slow Kia Forte Build
http://www.stevemead...ockUserAgent__1 < Old build 2005 Equinox
