Increase SQ with limited airpsace
boltdbz
I have a 95 Honda Civic, trunk is leaky so I've got 2 p3 12's in a prefab ported box with a Hifonics BRZ1200; running at 1 ohm. I've noticed the range on the low end is sort of limited, what's my problem? Will a custom box help? Or maybe I need to increase the ohmage
Custom box would help, and your sub´s are medium SQ and your amp under medium SQ qualit
The new p3s? My buddy has two and they sound clean as can be. The amp I'm not sure about, what do you know about Hifonics?
Lawls. Buy better equipment. Asking if a custom box would help means you haven't done any research whatsoever. Check tuning, low pass, subsonic, deck settings, box tuning. Could go on and on all day.
And I've done quite a few of those things; all I'm looking for are suggestions on what all should be on my checklist. so thanks
trunk is leaky
Fix this before you do anything ... ANY system is only as good as it's install ...
"trunk is leaky" = pressure lost ...
want more low end extension? get rid of that prefab that's probably tuned in the 40's and build a good ported box tuned in the low 30s
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
trunk is leaky
I meant to say "trunk is leaky so in the backseat I've got...." to clear up any confusion
Ok ... So you are saying that your trunk leaks water when it rains, so you have your enclosure installed on your back seat ...
Meaning that your enclosure is being muffled by your back seat ...
even worse ... this tells me that you actually have no idea what your current setup is capable of ...
Like I said ... get your car fixed before you go spending money on product that will not do any better than what you have in your current install ...
I'm not trying to be a pain in the ass in any way Sir, but I can tell you that no good can come from a sub enclosure "laying" on your back seat, Its loosing about 50% of it's capabilities (guestamation of course) ...
  • Who's Online   0 Members, 0 Anonymous, 1541 Guests (See full list)
