What amp to put with cresendo mids & highs
basshead5280
Ok so I'm debating on the 1100.4 or the dc 175.4. Mainly want to do the dc tho. What tweeter should I get the 4 or 8 ohm? And how would I wire them together? I'll get the crossovers from cresendo also.
Oh and is it ok to run channel 1&2 at 4ohms. Then channel 3&4 at 2ohms?
^^This, I wanted to know this as well!!. So im assuming to run it at 4ohms on ch1&2 and 2ohms at 3&4 he would need all 4ohm speakers for this to work?. I believe so but could be wrong..
According to 8ight, they share the same internals, DC would match better with your plans though
I don't know if the tweeter can handle 180 rms, I say get the 8 ohm version, it would be seeing around 90-100 rms if ohm's law is perfect
Wire the midbass's in parallel to get a 2 ohm load
You shouldn't need passive crossovers if you set the active ones correctly
For the last question, yes
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
You need good processing to run a active setup unless you want to sound like shit. You should probably run traditional components until you become more knowledgeable a out what to do and what to run. Components will keep up just fine.
2012 F250 Lariat 6.7, lifted on 22's and 35's
4 DSS Ethos 18's walled tuned low
2 Ampere Audio 7500.1's, Ampere 125.4
Rockford Pro Audio front stage
9 batteries, Mechman Elite 370 alt
Team DSS, Team Ampere Audio
2014 Meca Mod 3 TN State champ / 3rd place Mod 3 World Finals
32d73d87-e373-4a49-8914-d25decfa6dcc_zps
What about the crescendo CZ component set or the mezzo off the website? Anyone got any reviews on them?
1999 Durango
Current
2 15" DC level 3 15s
kenwood HU
Cresendo bc2000
Big 3 upgrade
Sky high car audio wire
Coming soon
Cresendo c1100.4
double din
New Build log
http://www.stevemeadedesigns.com/board/topic/168661-99-durango-dc-audio-package-in-and-box-almost-done/?p=2464991
Clean Build log
http://www.stevemeadedesigns.com/board/topic/171619-dc-audio-durango-clean-build/
they havent been released yet lol
Website says the new product comes out the 26th.. Lol
1999 Durango
Current
kenwood HU
Cresendo bc2000
Big 3 upgrade
Coming soon
Cresendo c1100.4
double din
New Build log
Clean Build log
Yeah I'd feed those pwx's all the power you can. 4 pwx 6's at 2 ohms each channel on 2 of the 1100.4 channels. And the other two channels I'd get 2 total 8 ohm tweets and give each channel 1 of those. So each pwx would see 150 watts and each tweet would see 90 watts if ohms law works perfectly ...
4 total pwx
2 total tweeters
1 total 1100.4
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
4 total pwx
2 total tweeters
1 total 1100.4
This is what im running....but i may upgrade and go from chan 1 & 2 1 tweet each at 8ohms to 4 tweets at 2 ohms. and get a 1600.2 with some 10s (:
Aside that get the C1100 IMO
  • Who's Online   0 Members, 0 Anonymous, 1154 Guests (See full list)
