DC Power 270a Only Making 170@2000rpm On Escalade
Does anyone know if this year escalade uses the ground-shunt thing? I know the new ones do. Not sure about this one
NO SHIT, I GET IT, I gave you stuff to check and do and you will have a resolution, trust me I know this SHIT!!!!! LMAO
Joo dont know shit and your wall is ugly! :peepwall:
You are a feg :)
TEAM SOUNDQUBED -- TEAM SOUTH
Evo X build log
Facebook page The Black Nasty
Neg terminal on battery will tell ya real quick
Evo X build log
I guess you missed my post lol, one of two things is happening
Bad connection or bad alt
That explains the voltage drop with low output current regardless of what amp is connected. OR there is a output delay due to PCM control.
I checked the connections and nothing ^seemed* loose or dangerous, but I didn't go over with a fine tooth comb by any means. I'd believe the lag: but this is 5-10 second issue we are talking about. Do you think that is still a possibility?
I was also thinking about the bad alt, since the power is almost exactly 2/3 what it should be - like a bad winding or something.
Greg: if you want to come up to my house one of these days, we take a really detailed look at everything
When I tested internal reg alts it took min of 10 secs for them to pick up output from a large pull over 200 amps. But since you are pulling less I would stand to guess it is connections or not enough grounding or bad ground.
Evo X build log
Here is another way to look at this.
The amplifier is going to draw current directly from the alternator. It is
going to draw as much as it can until the alt is tapped out. If the amp
still wants more power, then it is going to get into the battery
reserve. Theoretically, the D3100 should be able to power the rf2500 by
itself even without the alternator.
You could very easily have a bad alternator and a bad battery.
Oh and CJ lying is a bannable offense too!!!!
Evo X build log
I understand that this isn't the point of the topic but like Audiofanatics said, if your amp is protecting on a 15sec burp with a single D3100, car on or off, you have other issues to worry about than the alt not putting out max amperage.
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
An opinion cannot be considered a lie :bigok:
I will check it tomorrow exactly as you suggested. Thanks for the help. I know all the connections are good because I just put in my new Shok Competition 0-ga today. But I will go over ever connection, every ground, every everything tomorrow with a fine-toothed comb before calling DC on Monday.
2006 Cadillac Escalade
2/3 drop on 28" wheels
Two RE SX 18" subs
RF T2500-1bdCP amp, 3531watts on birthsheet
Custom carbon fiber sub box
EVERYTHING else is stock, for now
149.4 @ 37hz, Termlab, dash, open window on two AQ3 18s all stock electrical, wired to .25 ohm on a RF T2500
148.8 @ 36hz, Termlab, dash, open window on one AQ3 18 all stock electrical, wired to .5 ohm on a RF T2500
147.8 @ 38hz, Termlab, legal, sealed on two RE SX 18s
146.4 @ 36hz, Termlab, legal, sealed on one RE SX 18
Link to my hack-built, stupid, carbon fiber wasting project.... http://www.stevemeadedesigns.com/board/topic/149946-carbon-fiber-box-update-1494db-37hz-on-tl/
http://gifsoup.com/NDM3MTc1MQ
  • Who's Online   1 Member, 0 Anonymous, 957 Guests (See full list)
