DC Power 270a Only Making 170@2000rpm On Escalade
Also what does the battery rest at truck off after sitting for like 5-6 hours?
TEAM SOUNDQUBED -- TEAM SOUTH
Evo X build log
Facebook page The Black Nasty
NO SHIT, I GET IT, I gave you stuff to check and do and you will have a resolution, trust me I know this SHIT!!!!! LMAO
I will check it tomorrow exactly as you suggested. Thanks for the help. I know all the connections are good because I just put in my new Shok Competition 0-ga today. But I will go over ever connection, every ground, every everything tomorrow with a fine-toothed comb before calling DC on Monday.
It could be as simple as one nut/bolt that just isnt quite tight and is wiggling. It is usually something simple that you thought you did and just overlook.
yea just because you looked a few times doens't mean the loose connection isn't there....it took my dumb self about 6 to 8 times going through my old tahoe before i found my loose connection. when you think you've checked enough, check again lol
You were having this exact problem.
350a alt with 3 XP3000s running a DC 5k at .5 ohm. Major voltage drop for no reason. Solution was as simple as 1 loose wire.
I agree, but I have gone over it several times, both recently and months ago. Never hurts to go over everything again, and I will, but my setup is super-simple. Not like there is a lot of connections to get loose. About the only way I could make connections better would be to solder them. All grounds are to the frame, with the frame freshly tapped and sanded down to a bare metal connection.
BTW, I drag race a very fast street car and built it all myself. I usually don't leave loose connections or untightened bolts and everything is triple-quadruple checked. Missing something simple on an 8-9 second street car can get a guy killed.
2006 Cadillac Escalade
2/3 drop on 28" wheels
Two RE SX 18" subs
RF T2500-1bdCP amp, 3531watts on birthsheet
Custom carbon fiber sub box
EVERYTHING else is stock, for now
149.4 @ 37hz, Termlab, dash, open window on two AQ3 18s all stock electrical, wired to .25 ohm on a RF T2500
148.8 @ 36hz, Termlab, dash, open window on one AQ3 18 all stock electrical, wired to .5 ohm on a RF T2500
147.8 @ 38hz, Termlab, legal, sealed on two RE SX 18s
146.4 @ 36hz, Termlab, legal, sealed on one RE SX 18
Link to my hack-built, stupid, carbon fiber wasting project.... http://www.stevemeadedesigns.com/board/topic/149946-carbon-fiber-box-update-1494db-37hz-on-tl/
http://gifsoup.com/NDM3MTc1MQ
I just went out and checked. It is at 12.9 volts. Truck has been sitting for just over 4 hours.
Two RE SX 18" subs
Connection could all be solid, but seeing as tomorrow is Sunday and you couldnt get through to DC POwer until Monday anyways, those are the next logical thing to check.
Bad equipment is always a possibility, I have gotten a DOA alt, and had a d3100 go bad on me as well, shit breaks. BUT you also want to make sure you have checked everything on your end before you go and pull the alt and or battery and have to pay shipping to send it in to be checked out.
One thing I would like to see you try, is un hook the battery from the alternator and try and run the amp on the battery alone. Start off at half volume and see what it does. If the d3100 cannot support a RF2500 at half volume, then the issue may be the battery itself.
^^^^^^^^^ x2 a bad batt will easily thrash an alt.. hopefully not the case.
Setup:
2010 Hyundai Elantra
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
DD M3b and 2 12" AQ HDC4s
Granted it needs to be load tested but considering it has been sitting for 4 hours and has excellent resting voltage I would say the battery is fine.
Evo X build log
  • Who's Online   0 Members, 0 Anonymous, 920 Guests (See full list)
