Need advice on enclosure for DD 9512
this is one of my builds i used to primarily use only atomic subs....im changing it up a bit now....this is a friends car with the 1 DD 9512 with the 2 bamfs
my personal vehicle which is the same toyota corolla is on a sundown build im currently waiting on my 12 inch v3`s dual 1 ohm to run off a Te4001d....38hz....2.6 net cubes
Vehicle: 2000 Toyota Corolla Limited S
Head Unit: DEX 99rs pioneer
Speakers
Sub treble/High mid : 2 1.4 inch throat 2080 18 sound drivers neodyium with wave guide
Tweeters: 2 Mtx dome, 4 APT eminence super tweeters
Mid Range: 2 18Sound 6" 6ND410 NEO,2 18 Sound 10" 10NDA610 NEO
Low Mid Range: 2 18 Sound 10 NMB420
Sub: 2 Z-12 V.3 D1 - Sundown Audio
Amplifiers
Sub treble/High Mid: MTX Audio TA5302 Thunder
Tweeters: JL Audio e4300 4-Channel
Mid range: MTX Audio TC3002
Mid range: MTX Audio TA7402 Thunder 7402
Low Mid Range: MTX Audio TA7402 Thunder 7402
Sub: MTX Thunder Elite 4001D
Alternator: 220amp mechman
Batteries: 3 D3100 XS Power
I'd run different amp(s) honestly. Make sure your box has 15.5-16.5 inches of port surface are per cube. I'd say tune 34-38. I don't like running great equipment with not so good equipment, but then again that's me, never been a fan on PA. Make sure your electrical system is decent as well.
I'd ditch the 2 PA amps, and buy a solid 2k rms amp. As for the enclosure, I'm not sure. I've never messed with DD, so I don't know how they do in different enclosures. Good luck OP, and hope this helps.
*Rebuid in progress*
A DD m2b ibet for 480 is better than what he is putting in.
or even SQ 2200
crescendo 2k or 3.5k
DC 2k
like get a quality amp man. and amp is in my opinion the most important part. of the sub stage.
try that thing in 2.25-3 cubes depending on power
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
  • Sorry fellaz it is not the 9512 only it is the new 9512i...i spoke to the guy pertaining to the amplifier and he is goin to change it to the te4001D....and to bump it up a bit hez gonna put in another 9512i....2.6 net cubes is what we are goin to run i will post pics of the build! :nuts:
Speakers
Amplifiers
Lol when u say Bad wat exactly u gettin at bad in a good way or in a bad way?....i have read that the speaker over excorts and damages in too big of an enclosure?
and the amplifiers are temporary i used them on a atomic apx 12 strapped at 2 ohms and i got 148.6 dbs window down.
148 with a single 12 is a great score , so why change that up to a sub that might be weaker ?
Why change the box at that ?
Though the sub vs amp amazes me .
Can't go all out on a sub then cheap out on amps...
Just never works out that way
  • Who's Online   0 Members, 0 Anonymous, 2702 Guests (See full list)
