I am considering buying 4 of the E-8 subs and running them off of an aq2200, I am also considering the sa-8 but don't know yet.
Not trying to make a vs thread so I will mostly keep this about the e-8. Do they get loud? By loud I am not talking about 160, or even 150. I will be building a ported box in a 2006 Scion XB. I hit 138 with 2 type-r subs in a prefab a few years ago so the vehicle is relatively easy to get loud with imo. That was without dynamat, on stock electrical with an alpine 500w mono block at an IASCA event in 2007 (dunno what meter was used).
I am looking to exceed that with this setup. I would imagine with the aq2200 (assuming the e-8s can handle that) and sundown subs in a properly built box I could do that. But... I don't know so that is why I am asking you guys. I have deadened the vehicle but still have stock electrical. I may do the big-3 but the stock alternator will be staying.
Also, while I am here... I have an optima blue top battery sitting around. Can I run my car off of that, and would I benefit in doing so? If not, would I benefit from putting it in the back? Didn't cost me anything and is in good shape so just wondering if I would gain anything by using it.
With the e-8 subs, how low could I expect them to play and still sound good? Thanks for helping a noob!
2006 Scion xB
2 Sundown SA12D2
Ported at 32hz
147 on non termlab (140-142 on TL)
Currently in a walled 4th @ 50hz (not metered yet)
Hifonics brz2100
Alpine Type-S Components
Kicker 300.2
Big 3 / Skyhigh 1/0 cca
Optima Blue Top
3 e8s ported at 32hz
135.1 sealed on dash @ 56hz
135.0 outlaw (I must have chosen song poorly lol)
Build log
'Brandon15zzz', on 09 May 2012 - 3:13 PM, said:snapback.png
May have been clipping but none fucks were givin.
We can't tell you how loud they will be. Flat out.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
I guess you to go with the SA 8 sub´s, The E 8 v 3 is a 300 watt RMS sub the SA 8 are a 500 watt RMS. You have a 2.2 K amp it´s not recommanded to overpower sub´s.
Sundownsub´s are known to take a beating sometimes twice than they rate, gains set with an O-scope or DD-1. Obviously losses with imprise and so on, i would go with
the SA 8´s they matching better to the power of your amp.
"in the abundance of water, the fool is thirsty" Bob Marley
nobody can say how loud anything will be...
those subs should handle a AQ2200..put the Optima blue in the back and do the big3 also
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
LOL
Here's the best answer to your question
http://www.stevemeadedesigns.com/board/index.php?app=forums&module=extras&section=boardrules
Or you can buy them and tell us
Wow, I don't see where I broke any of those rules, so thanks for being a tool to a guy new to the boards. I just imagined that in the Sundown forum that someone would own a set and maybe post their experience. I know damn good and well there is no magic calculator that gives a termlab score before you do the install. This was not a comparison thread as I specifically stated I wanted to keep it about the e-8s.. No wonder I haven't tried to get back into the car audio community...
Yes I stated my goal was to exceed my old system, but I didn't ask if my proposed setup would break 138, 140, 142.. etc... Without having a box design picked out you can't even start to look at the exact numbers... I was basically trying to see if anyone had the subs and what they were getting out of them. ie.. if someone is hitting 150db with them then they can get loud... setups will be different and vary drastically... but if I built an identical box, with an identical electrical system in an identical vehicle... I could reasonably expect at least ~similar~ results... no? I might not hit 150 with the same setup but assuming all specs are identical, we can agree I would almost certainly be louder than 130, no?
I also asked how they sound at lower freqs, and maybe I worded that wrong too lol.. But.... I can tell you first hand that Boss Shallow mount 10s sound like poo once you get below about 45HZ in a sealed box that meets the recommended size by the manufacturer, so I would think that someone could say "the e-8s" are capable of playing low freqs like a champ" or "they are nice subs but not really the best on the bottom end" or whatever the case may be. And I know that can be at least someone calculated using winisd or several other programs. I compared the sa-10s to my old Boss 10s and can easily say the sundown subs will perform better at lower frequencies when following manufacturers recommendations for the enclosure... I doubt anyone would argue otherwise right?
If somehow I did violate a rule that I didn't see in your ohsokindandhelpful post.. then I apologize and will take my questions elsewhere.
Edited by ncochran
2006 Scion xB
2 Sundown SA12D2
Ported at 32hz
Hifonics brz2100
Kicker 300.2
Optima Blue Top
Build log
Thank you, at least you were somewhat constructive.. I think everyone else misunderstood.... I wasn't asking "how many dbs will this do".. I was looking for advice on my battery, and trying to get peoples opinions on the e-8 subs and whether they might be a decent match for that amp.
Edited by ncochran
2006 Scion xB
2 Sundown SA12D2
Ported at 32hz
Hifonics brz2100
Kicker 300.2
Optima Blue Top
Build log
E8v3s or v2? And ibanender on YouTube put the v3 on a term lab and did a 147.4. The v3 is a nice sub, I got one so far and people tell me it sounds more like a 10. I got one of 520 watts rms and takes it no problem. Pretty loud for one, but my loud and you're loud are 2 different things, I'm more of SQ than SPL and don't plan on competing until I get a couple of em. I got mine a .66ft^3 tuned to 35hz and sounds good, next box ima tune around 30hz cause I play a lot of decaf and rap.
Edited by soBASED
Car:
- 2013 Honda Accord Sport 6MT
- aFe SRI
Electrical:
- Big 3 w/ Execution Audio 0/1 AWG OFC
- Stock Battery
Audio:
- JBL Power Series 6.5 Comps up front (Running off HU power atm)
- JBL Power Series 2-Ways in the rear deck (Running off HU power atm)
Subwoofer:
- Sundown Audio X-15
- CT Sounds AT1400.1D (@1 ohm)
Bedroom:
- Yamaha RX-V365
- Pair of Klipsch KG4.2's
- 2 E8v3's in a 1.34ft^3 tuned to 30hz
- No Amp yet..
- CoolMax ZU900B PSU for amp
In my room & previous car:
- Amp: Soundstream TX1.1300D @ 4 ohms (520 watts)
- T-Line Enclosure tuned to 32hz
YouTube : http://www.youtube.c...r8?feature=mhee
This topic is now closed to further replies.
  • Who's Online   0 Members, 0 Anonymous, 1665 Guests (See full list)
