What in Gods name happened to my amp? Lol
Raptorman
what size welding wire are you using?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
you really should have 2/0 welding cable instead of 1/0.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
OR dual inputs, without disto blocks for sure.
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
Yeah it's 1/0, but it has never gotten even warm or anything. It barely fits in the amp terms too. The only piece that got fucked up was the piece coming off the distro block to the + amp, every other wire to/from the batt/distro block is all good.
Pics incoming.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Lol sheeeeeeiiiiiiiiiiiitttttttttttttttttttttt.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
I don't think it's the wire, I seen Onebadmonte use that exact wire to power his warhorse without issues
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
at 1:56 in the video it looks like the wire from the alt to the battery has a cut in to it if it is then its shorting out causes the wire to get hot.
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
Nah that was just a glare, and even then it's not close to touching anything near it.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
idk it getting that hot its a short I've seen loose wire before and it doesn't melt anything but a short or ground issue sure does that.
2 sundown sd-2 d4
flex tech
box design by Joe X
  • Who's Online   1 Member, 0 Anonymous, 1473 Guests (See full list)
