for shits and gigs??!!
there will be 3 wires, 12v constant, ground and 12v switched
PSN: Rcp_soundz
Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at.
I'll stick a 300 amp fuse in a potato and sell it to you for $2k.
1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
Where would you hook up any other volt meter?
You can look at stinger for shits and gigs but never , I repeat NEVER, about the VM-1
MOB-MOBILE: 2005 Honda Accord 5-Speed System: (1) Sundown Audio SA-15 (1) MB Quart ONX1.1500D (1) Kenwood KDC-248U
Speakers:
-Rear Dash: (2) Clarion SRQ6932R 6x9's SOLD
New MOB-MOBILE:
2011 G37S Sedan
System:
TBD
Instagram (18+) : DabsWitaBudget415
from what yours asking .... you did not have to make up some bullshit .. you should of just ask how to hook up a volt meter (vm-1 same shit) we are all lost in the car audio industry including me ...... btw red wire(power)(12v) black wire (ground) blue wire (remote)(12v on/off switch) were to hook up ??? were ever da hell you want it to be
[sharedmedia=garage:vehicles:2273]
If I were hooking up a volt meter, I would want to hook it up at the amp power supply to monitor the voltage the amp is getting.
This.... Also why my toolmaker dual inputs have voltmeter holes in between the inputs on both the positive and the negative
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
  • Who's Online   0 Members, 0 Anonymous, 2125 Guests (See full list)
