bad amp?
voxigenboy
LOL lucky an RF amp works after 6 years?
the man that told you that is the most idiotic person on earth.
I guess I should win the lottery with my two working punch amps from 99-00
I have a feeling it has something to do with the remote wire. Try a different source and see if it turns on.
If you have a DMM use it to check the remote wire.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
update: everything checks out fine. it was a blown fuse on the main ground cable. it looked like it was still ok but ended up not being the case. it was the same fuse that blew about 3 - 4 months ago.
so, would upgrading the cable & fuse stop this from happening?
did you put higher rated fuses in it last time and if so how much higher
Maybe I should put a fuse on my grounds too lol must be something new
sorry fellas, if you want to know how to build a computer, produce your own dance music... i'm your guy. but with car audio i'm really just going off of what people are telling me. i've had shop(s) install everything. most i've done myself was just change out an amp/subs & replace fuses. wish i knew more but seems i have a ton ofresearch ahead of me.
the fuse i'm talking about though is up front near the battery/fuse box and is attached to a red cable... so since black is ground, i got that mixed up.
  • Who's Online   0 Members, 0 Anonymous, 1091 Guests (See full list)
