Wiring A Dual 1 Ohm Sub Question
bumpin04voy
well i just picked up the BTLs from Ernesto...
they are dual 1 ohm subs
now if i wire one of them to 2 ohms will that work on an amp that is only 2 ohm stable or is it gunna be less than 2ohms and im gunna end up needing a 1 ohm stable amp
i plan on running one sub per amp
Avic N1
rockford 400.4
type-r comps all around
(2) 18" Fi BTLs fully loaded
11 cu ft. vented box 34hz
(2)RD Audio 1750.1
(4) optimas
no u can wire it up to 2 ohm and be fine
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
IIRC the actual impedance is somewhere around .7 per coil. If that is the case then you might be slightly under 2ohms at times. You should be okay unless the amps youre running have really sensitive protection curcuitry..
2001 Blazer
Pioneer 5900IB - (2) DC Level 3 10"s - Sundown 1500D
i hope these amps dont if they do i guess its sell them and buy some new amps to run them
Avic N1
rockford 400.4
(2)RD Audio 1750.1
(4) optimas
with impedance rise youll bee around 2 ohms ;)
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
  • Who's Online   1 Member, 0 Anonymous, 1992 Guests (See full list)
