As-21 Posted March 15, 2013 Report Posted March 15, 2013 (edited) i noticed today that my sub making a rattling sound and hit noise when i crack the volume up. i didn't touched the gain for a while and the noises come when i am on high volume. it wast like this before i must say. so i took the sub from the box to see i i can hear from where this noise is coming. didn't hear nothing special i noticed that one of the leads is kinda touching the cone and there is leads marks on the cone. when i play the sub all volume up on free air i don't hear hitting sound only low rattling sound when i put it back i can hear something hitting or hitting sound and rattling on a bit low volume. Ive also checked the cooling hole on the bottom if there is a FOD in it didn't find nothing and the sub looks aligned. what can it be ? is it possible the spider lost there stiffness and i am hitting now the XMAS ? Or is it the box fault ? too much port area ? or the port area is too little ? Edited March 15, 2013 by As-21 Quote Hertz HSK 165XL Celestra FA475xDC Audio 3.5KDC Audio level 5 12 inchXS Power 6500 on the front.XS Power 3100 on the back.Knukonceptz 0 gauge an 10 gauge OFC wire.
fox_racin4 Posted March 15, 2013 Report Posted March 15, 2013 If the noise gets worse in the box, could be a broken box, or a loose dustcap ( more backpressure on cap while in the box) Quote 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
corona_jeff Posted March 15, 2013 Report Posted March 15, 2013 Box specs? Power? We could use more info Quote
Real96SS Posted March 15, 2013 Report Posted March 15, 2013 I think the DC subs come with a velcro patch on them to eliminate tinsel slap.So what are the specs of said box so we can tell if your bottoming out the sub Quote Vehicle 2007 Chevrolet Avalanche(Co-Co) DNX9980HD 6 Team Fi 15's(King Edition) 3 DC 9k's 8 Nendo PWX 8's 4 Custom Steg 4" Super Tweeters 1 DC Audio 175.4 1 DC Audio 90.4 Rockford 360.3 3 DC Power 370xp Alts(Externally regulated) 21 D1600's 2 D4800's All SMD RCA's AudioTechnix Deadner Viper Alarm My YouTube- http://www.youtube.c...NG?feature=mhee Link to buildlog- http://www.stevemead...4-15s-2-dc-9ks/ Link to UBL- http://www.stevemeadedesigns.com/board/topic/165059-ublkings-avalanchecoco-new-build-starting8-king-edition-15-team-fis-in-a-wallyes-a-wall/
As-21 Posted March 16, 2013 Author Report Posted March 16, 2013 (edited) this are the specs 1.5 cuft net. 16 inch^2 per cubic feet tuned to 34hz, here is the Google sketch file if it helps. http://speedy.sh/VwDKw/LVL5-DRFAT-1.skp just click on download above. ill try to upload a video so you guys can hear it too, this is my setup: Hertz HSK 165XL Celestra FA475xDC Audio 3.5KDC Audio level 5 12 inchXS Power 6500 on the front.XS Power 3100 on the back.Knukonceptz 0 gauge an 10 gauge OFC wire. 110 AMP alternator Edited March 16, 2013 by As-21 Quote Hertz HSK 165XL Celestra FA475xDC Audio 3.5KDC Audio level 5 12 inchXS Power 6500 on the front.XS Power 3100 on the back.Knukonceptz 0 gauge an 10 gauge OFC wire.
As-21 Posted March 16, 2013 Author Report Posted March 16, 2013 (edited) this is a video you can hear what i am talking about: the buzzing sound isn't from a bad recording that what i hear when the subs operates http://youtu.be/IcCz63rBEpI also i noticed that the cone and spider connecting place on one side of the sub is dry or failed apart could it be the reason ? here is a picture of the dry side: and here the other side for compression: this picture is for the leads mark couldn't get clear picture off it. Edited March 16, 2013 by As-21 Quote Hertz HSK 165XL Celestra FA475xDC Audio 3.5KDC Audio level 5 12 inchXS Power 6500 on the front.XS Power 3100 on the back.Knukonceptz 0 gauge an 10 gauge OFC wire.
As-21 Posted March 16, 2013 Author Report Posted March 16, 2013 i installed the sub inverted and played again on the area that i hear the noise the loudest i can see a straight Square shaped of gray paint on the voice coil i couldn't take a picture off it because i can see it only when i play a track. it is where one of the leads going to the coil not the same lead as before its different lead is it out of align ? is it hard to fix that kind of problem ? Quote Hertz HSK 165XL Celestra FA475xDC Audio 3.5KDC Audio level 5 12 inchXS Power 6500 on the front.XS Power 3100 on the back.Knukonceptz 0 gauge an 10 gauge OFC wire.
Kyblack76 Posted March 16, 2013 Report Posted March 16, 2013 i installed the sub inverted and played again on the area that i hear the noise the loudest i can see a straight Square shaped of gray paint on the voice coil i couldn't take a picture off it because i can see it only when i play a track. it is where one of the leads going to the coil not the same lead as before its different lead is it out of align ? is it hard to fix that kind of problem ? You beat me to it.. I was going to suggest inverting the driver, and watching..... Nice job on the trouble shoot. Quote SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
As-21 Posted March 17, 2013 Author Report Posted March 17, 2013 here is the grey color on the coil its about inch width and 2 or 3 lanes of the coil very straight and square shape:what you guys think ? where this coming from ? Quote Hertz HSK 165XL Celestra FA475xDC Audio 3.5KDC Audio level 5 12 inchXS Power 6500 on the front.XS Power 3100 on the back.Knukonceptz 0 gauge an 10 gauge OFC wire.
sbg Posted March 17, 2013 Report Posted March 17, 2013 I just had the same problem Friday! Had a sound just like that in my sub. Took my sub out and took a look at and didn't see a problem, but I was thinking to my self man this sub has a lot of dust on it, so I blew through the cooling holes and a chip of MDF came out! After that I hooked it back up and it was fine. Don't know if that's your problem but u could try that Quote 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
