DC Sound Lab
rattling sound and noise from my level 5 12 inch
i noticed today that my sub making a rattling sound and hit noise when i crack the volume up.
i didn't touched the gain for a while and the noises come when i am on high volume.
it wast like this before i must say.
so i took the sub from the box to see i i can hear from where this noise is coming.
didn't hear nothing special i noticed that one of the leads is kinda touching the cone and there is
leads marks on the cone.
when i play the sub all volume up on free air i don't hear hitting sound only low rattling sound
when i put it back i can hear something hitting or hitting sound and rattling on a bit low volume.
Ive also checked the cooling hole on the bottom if there is a FOD in it didn't find nothing and the sub looks aligned.
what can it be ?
is it possible the spider lost there stiffness and i am hitting now the XMAS ?
Or is it the box fault ? too much port area ? or the port area is too little ?
Edited by As-21
Hertz HSK 165XL
Celestra FA475xDC Audio 3.5KDC Audio level 5 12 inchXS Power 6500 on the front.XS Power 3100 on the back.Knukonceptz 0 gauge an 10 gauge OFC wire.
I think the DC subs come with a velcro patch on them to eliminate tinsel slap.So what are the specs of said box so we can tell if your bottoming out the sub
Vehicle
2007 Chevrolet Avalanche(Co-Co)
DNX9980HD
6 Team Fi 15's(King Edition)
3 DC 9k's
8 Nendo PWX 8's
4 Custom Steg 4" Super Tweeters
1 DC Audio 175.4
1 DC Audio 90.4
Rockford 360.3
3 DC Power 370xp Alts(Externally regulated)
21 D1600's
2 D4800's
All SMD RCA's
AudioTechnix Deadner
Viper Alarm
My YouTube- http://www.youtube.c...NG?feature=mhee
Link to buildlog- http://www.stevemead...4-15s-2-dc-9ks/
Link to UBL- http://www.stevemeadedesigns.com/board/topic/165059-ublkings-avalanchecoco-new-build-starting8-king-edition-15-team-fis-in-a-wallyes-a-wall/
this are the specs
1.5 cuft net.
16 inch^2 per cubic feet
tuned to 34hz,
here is the Google sketch file if it helps.
http://speedy.sh/VwDKw/LVL5-DRFAT-1.skp
just click on download above.
ill try to upload a video so you guys can hear it too,
this is my setup:
Hertz HSK 165XL
Celestra FA475x
DC Audio 3.5K
110 AMP alternator
Edited by As-21
Hertz HSK 165XL
this is a video you can hear what i am talking about: the buzzing sound isn't from a bad recording that what i hear when the subs operates
http://youtu.be/IcCz63rBEpI
also i noticed that the cone and spider connecting place on one side of the sub is dry or failed apart could it be the reason ?
here is a picture of the dry side:
and here the other side for compression:
this picture is for the leads mark couldn't get clear picture off it.
Edited by As-21
Hertz HSK 165XL
i installed the sub inverted and played again on the area that i hear the noise the loudest i can see a straight Square shaped of gray
paint on the voice coil i couldn't take a picture off it because i can see it only when i play a track.
it is where one of the leads going to the coil not the same lead as before its different lead
is it out of align ?
is it hard to fix that kind of problem ?
Hertz HSK 165XL
You beat me to it..
I was going to suggest inverting the driver, and watching..... Nice job on the trouble shoot.
here is the grey color on the coil its about inch width and 2 or 3 lanes of the coil very straight and square shape:
what you guys think ? where this coming from ?
Hertz HSK 165XL
I just had the same problem Friday! Had a sound just like that in my sub. Took my sub out and took a look at and didn't see a problem, but I was thinking to my self man this sub has a lot of dust on it, so I blew through the cooling holes and a chip of MDF came out! After that I hooked it back up and it was fine. Don't know if that's your problem but u could try that
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
  • Who's Online   1 Member, 0 Anonymous, 1497 Guests (See full list)
