Pauly1987 Posted March 16, 2013 Report Posted March 16, 2013 So been thinking of moving to a round sub (sa-12 sundown) from my current set up in my picture 2 15 l7 in a 12 cube box This is not a vs thread just looking on some info on these sundowns I've read they take 600w rms and like 2 cubes ported (correct me if I read wrong) I would like to keep the same box design that I have now speakers facing forward and ports on top My amp is a zx2500 and I don't plan on upgrading that I want 4 sa-12 do you think the zx2500 can push them? Or would I not be happy? Also how big of a box? 10 cubes ported I'm thinking cause I'm under powering them! Open to ideas Reason behind this Is I just want more BASS
sbg Posted March 17, 2013 Report Posted March 17, 2013 From what I have read on here them SA 12s will take 1000 rms each all day 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
Krakin Posted March 17, 2013 Report Posted March 17, 2013 If you have the room I would opt for going SA-15's just cause of the cone area being lost. Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener.
Joe X Posted March 17, 2013 Report Posted March 17, 2013 The L7 15s radiating surface is about the same as 2 12s (so definitely higher than 15s) and 16.1 mm xmax the SAs will have little higher xmax, so displacement wise not a compelling upgrade, since you have 12 cubes a couple of 18s with higher xmax say 25mm could potentially be more of an upgrade, also for 4 SA12s look at 4K power.
Swordlordboy1234 Posted March 17, 2013 Report Posted March 17, 2013 4 SA 12's would give you a better sounding system IMO better then the l7's SA's sound great and are under rated. A 2500 will keep 4 of them satisfied but if you ever get the chance for a 3500 or a second 2500 and lower the gains on the pair from -10 db with the dd1 to -5db for the safety of your woofers. Their limit IMO is 1000rms not 600 but they will take 600 all day long and all next week, no rest. 24/7. If you gave them 1250+ each they start to not like you as much and get a bit warm. But will be great just don't bang on them for hours on hours. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
Pauly1987 Posted March 17, 2013 Author Report Posted March 17, 2013 So not a good option to be upgrading to 4 12? 2 18 is what u guys are saying?! Which 18 then would meet my needs and like a box that's 12 cubes 6 per chamber? I imagine I can use the same box just cut the baffle to accommodate the 18's The 18's both would need to be happy with my amp zx2500!
Krakin Posted March 17, 2013 Report Posted March 17, 2013 ZVX-18 : 4 cubes Z v.3 18 : 4 cubes DC level 3-6 : 6 cubes Fi BL 18 : 5-8 cubes *Also a lot more Fi subs to choose from that are 18" If you want to go real big the SMD 18's are 4-7 cube. Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener.
Bradprobert Posted March 17, 2013 Report Posted March 17, 2013 ZVX-18 : 4 cubes Z v.3 18 : 4 cubes DC level 3-6 : 6 cubes Fi BL 18 : 5-8 cubes *Also a lot more Fi subs to choose from that are 18" If you want to go real big the SMD 18's are 4-7 cube. those to me would be a great choice but you will have to plan on upgrading to more power if you want to get the results you are hoping for. [sharedmedia=garage:vehicles:2223] 4th-order under rear seat build log: http://www.stevemeadedesigns.com/board/topic/165708-4th-order-under-rear-seat-chevy-extended-cab/#entry2410477 SD, thank for the input. I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
Krakin Posted March 17, 2013 Report Posted March 17, 2013 Yeah if you want to run 2 18's your gonna need to kinda upgrade everything lol. Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener.
Joe X Posted March 17, 2013 Report Posted March 17, 2013 So not a good option to be upgrading to 4 12? 2 18 is what u guys are saying?! Which 18 then would meet my needs and like a box that's 12 cubes 6 per chamber? I imagine I can use the same box just cut the baffle to accommodate the 18's The 18's both would need to be happy with my amp zx2500! If you want to increase your output in a meaningful way, in your space, 2 18s seem a good option, DC level 3 with coil upgrade or Level 4s can work on that power for example. To take full advantage of an upgrade, yes upgrade power, a wide array of 2x18s can work on a single 3.5K amp.
