Joe X Posted March 19, 2013 Report Posted March 19, 2013 also check your torres sheet as theres something very wrong with the port volume it should be in the mid 3's not mid 5's Pretty much final Vb= 14.6 cubes, Fb = 29.3Hz but those are still within OA ranges. Lame tuning for an extcab though.
john253a Posted March 19, 2013 Report Posted March 19, 2013 idd still tune it high, thell still get low even at 37hz
jeffrm Posted March 19, 2013 Author Report Posted March 19, 2013 I want it to be a loud groundpounder. 03 tahoe z71 4 death penalty 18s 2 ampere audio 3800s @ .5 each 18v 156.7 @ 35hz 158.5 @ 50hz
john253a Posted March 20, 2013 Report Posted March 20, 2013 idd still open the port up too 7" wide and 16long and atleast run 35hz
jeffrm Posted March 21, 2013 Author Report Posted March 21, 2013 my last wall was tuned to 38 and it didn't get as low as I wanted. most songs sounded like crap. that's the reason for tuning so low. 03 tahoe z71 4 death penalty 18s 2 ampere audio 3800s @ .5 each 18v 156.7 @ 35hz 158.5 @ 50hz
SnowDrifter Posted March 21, 2013 Report Posted March 21, 2013 If you are looking to get low, this looks fine If you want more output down low, I'd make the box a bit bigger. But right now for a daily box - something that will play low but not fall on it's face with the high end: that looks fine ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
jeffrm Posted March 24, 2013 Author Report Posted March 24, 2013 so you're saying this box will dig pretty low but still have some good high end? I listen to a lot of DJSNT. so some songs are in low thirties and some in low forties. I'm just wanting something that people will be impressed with. low power subs on low Watts. I have an RD 3250 on all 4 at 1 ohm. 03 tahoe z71 4 death penalty 18s 2 ampere audio 3800s @ .5 each 18v 156.7 @ 35hz 158.5 @ 50hz
Joe X Posted March 24, 2013 Report Posted March 24, 2013 Take a look at your same box entered in new Torres version: 1.7 cubes difference!. So which version you believe is right? Through modeling it seems it will peak quite a bit near tuning, 40Hz wont be as loud. I'd seek to tune higher like 32-34
jeffrm Posted March 24, 2013 Author Report Posted March 24, 2013 How is there that much difference? Im wanting good low end but also dont want to slack on the lower 40hz range. 03 tahoe z71 4 death penalty 18s 2 ampere audio 3800s @ .5 each 18v 156.7 @ 35hz 158.5 @ 50hz
Joe X Posted March 24, 2013 Report Posted March 24, 2013 Both the old Torres (that you use) and the new one have have problems calculating port displacement, the old one fails badly with big fat ports like those in walls. He has stated in his thread that he will fix them but who knows when that will happen. For your project I would recommend using the new version of Torres and give about 3.2 cubes net per sub and a tuning of at least 32Hz and the 40s will benefit from doing that.
