2x Lanzar Optidrive 1535D - not sure if burning VC or glue or my amp
I would say that amp could get 1500 to 2k, 2k if your super lucky
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
BladeIce will help
They're in cranfield, an hour and a halfish on the m1.
http://www.bladeice.com/index.php/about
European distributor for the smd tools too :drinks:
i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah..
You want this to happen to you? Give decent handshakes people.
I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
box specs?
Not sure of the dimensions, will measure when I get home but it's definitely tuned to 32hz, with a single port (L shape bandpass inside)
Low notes and trying to move air requires lots of powa
I was able to move loads of air with my previous settings (bass boost etc) even with the port facing up and me in the driver seat. Quite a lot of air actually. Also noticed that I smelt a bit of burning today with everything down, the subs were cold and no smell in the port. However the amp was quite warm, so maybe a wire could be burning?
BladeIce will help
I'll check them out soon, cheers
Check grounds and all other connections to make sure they are solid. If you're amp is struggling or clipping that can cause heat. Bass boost normally clips your signal and clipping = heat which is probably why you were smelling your subs. You were running 1 before right? Now you're running 2? When you go from 1 sub to 2 subs your dividing the power on your amp so its possible you are lacking power which is why your setup sounded better with 1 than it does with 2. Upgrade the amp and electrical (battery, alt etc.)
The grounds have been re-checked last week, and all are fine. However the connections on the amp are only 4 gauge, so I've had to strip down my 0 gauge manually. Purchased some 0 gauge -> 4 gauge cable reducers so should get a bit more power.
I was running 1 around a month and a half ago now, but I meant before as in when I had my bass boost on full and bass enhancer on HU on level 1/2, last week. Also managed to get front windscreen and all passenger window flex, which I lack now
if im not mistaken this is one of the knocks on the optidrive. they smell. which makes it tough to tell if you are clipping and burning coil or if its just the smell.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 689 Guests (See full list)
