Best 1000w rms @ 2ohm amplifier for under 200$?
hayden55
I have a hifonics hfi1000.1d on my sundown sa-8v2 in a really good box. It gets pretty loud but just not loud enough. At 2 ohms im suppost to be getting 750, but it sounds like 650. What is the best 1000w rms at 2omh amplifier guys under 200 in your opinions that is cea-2006 rated? Upgrade to a bigger hifonics that is certified? Im selling my current amplifier in the next couple weeks to a friend so i will upgrade then.
I figured I would listen to what you guys have to say since you guys told me not to get the hfi1000 and you guys were right, im not happy with it.
2006 Ford Ranger XLT 3.0l-Rockford Fosgate 6x8s 3-ways- Sundown Audio SA-8- 3.64ft3 tline box in naked mdf- Kicker zx750.1- 0/1 Gauge wires- Pioneer head unit stuff to come:16 steve meade 18's7 rockford fosgate t15000bdcpa fleet of escaladeslol jk new car?
there is no audible difference from 650 to 750.you are just pulling numbers out of the air.
cea means Jack.
I can't think of a single good amp at that price with that power level
not to be rude but did you read my post?
i would like to upgrade to a 1000w rms amplifier at 2 ohms for under 1000w rms. My current amplifier is not cea-2006 rated so i do not think it is putting out a good 750 but more like 500-650. A good example of a non cea-2006 rated amplifier would be anything made by Boss Audio. If it doesnt matter you should really go check out some of their 4000w amplifiers for 90 bucks
Bigger hifonics amp, though don't go with the Hifi series, BRZ does rated if you can find them.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
He was referring to your inaccurate guesstimate of 650 rather than 750. The reason it's not "enough" for you is because it's a single 8" sub. Yeah, they are some little beasts, but at the end of the day, you've still only got a single 8.
Also, why does everyone think being double the RMS to a sub goes anything special. The sub was built for what, 400 Watts RMS? Do you know what a sub does with that extra 600 Watts? Not a lot, but creates a lot more heat.
Time for a 1200 watt at 1 ohm amp with a second 8... ;)
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
@Swordlordboy1234 Time for a 1200 watt at 1 ohm amp with a second 8... ;)
I love the way you think! The only thing is i cant afford another sa-8v2 and i have no room for it. Im in an extended cab ranger so i atleast have to have a little storage space inside the cab.
@CleanSierra Also, why does everyone think being double the RMS to a sub goes anything special. The sub was built for what, 400 Watts RMS? Do you know what a sub does with that extra 600 Watts? Not a lot, but creates a lot more heat.
It was rated for 500w rms but i have seen a guy throw an ns-1 at it on youtube. Ive actually sent him a couple messages before and he says he runs it everyday with no problems. That like 6500w rms daily. O.O
What about the GLX series, the ZRX series, and the BRZ have been discontinued for the newer BRX series and are kinda pricey. Brz sounds good though. And then whenever i decided to upgrade i can run 1 ohm and up my power for 2 subs.
  • Who's Online   1 Member, 0 Anonymous, 463 Guests (See full list)
