Verlaist Posted March 20, 2013 Author Report Posted March 20, 2013 13.8 2002 Forester Alpine INE-W927HD, Hertz Mille Legend 3 way 2 DC Level 6's,Bit One Audio , Audison Voce Due and Quattro, 4 Twisted Sounds 3.5K, 8 G31 Batteries, DC Power XP 270 Alternator. All Sky High OFC wire.
Jessica Posted March 20, 2013 Report Posted March 20, 2013 Pull the rubber boot back on that connection and take another picture. I dont see any solder. edit spelling Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
SnowDrifter Posted March 20, 2013 Report Posted March 20, 2013 13.8 Where are you reading the voltage from? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Verlaist Posted March 20, 2013 Author Report Posted March 20, 2013 13.8 is the voltage not the issue. Upon pulling the wire from alt not only were some burnt but also cut (beneath the eletrical tape.) I am surmisine its was arcing upon acceration or something. goin to get a torch and some soilder tommorow and start fixing my termination point as per suggestions, as well as the 1/0 from the alt to the battery. So far no cut outs after acceleration after pulling bad wire. havent pushed the subs dus the dinky 2 stock wires will do tommorow as well. I have learned more in 1 forum post than anything from this idoit shop here in town. You guys rock! Thanks and keep bumpin! 2002 Forester Alpine INE-W927HD, Hertz Mille Legend 3 way 2 DC Level 6's,Bit One Audio , Audison Voce Due and Quattro, 4 Twisted Sounds 3.5K, 8 G31 Batteries, DC Power XP 270 Alternator. All Sky High OFC wire.
Jessica Posted March 20, 2013 Report Posted March 20, 2013 Take a look in this thread for tips on soldering big wire. http://www.stevemeadedesigns.com/board/topic/6399-how-to-solder-large-gauge-wire/ I only asked because you said you crimped and those are not crimp connectors. Good luck man, hope you get it straightened out. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Verlaist Posted March 21, 2013 Author Report Posted March 21, 2013 13.8 at amp 2002 Forester Alpine INE-W927HD, Hertz Mille Legend 3 way 2 DC Level 6's,Bit One Audio , Audison Voce Due and Quattro, 4 Twisted Sounds 3.5K, 8 G31 Batteries, DC Power XP 270 Alternator. All Sky High OFC wire.
newls1 Posted March 21, 2013 Report Posted March 21, 2013 crimped termination let me get some pics up here in 5How did you crimp it? Just FYI, this is not a crimper. I don't care how it's marketed or if you tried to use it as such. It's not a crimper. Nor is this Or this Or heaven forbid you try to use this... These are not crimp terminals either. Once more, I don't care who does it or what you may think. They are solder terminals, not crimp ones This is a crimp lug And this is a crimper If you tried any of the above combinations, your connections are a fail. Re-do them. Either cut them off, re-strip, and solder with new terminals. Or cut them off and re-crimp properly I disagree... Pic #1 makes for a great crimper if used correctly. YOu might have had bad luck with one, however ive been using one for 15 years and never a single issue.... I love my staffie So anti FACEBOOK it isn't even funny
pontformulalt1 Posted March 21, 2013 Report Posted March 21, 2013 I am running a mechman and kicker amp I have the same issue my amps turn off when leaving a stop light...its because the alt. May not be on at a low r.p.m. And when you accelerate the alt. Is turning on and throwing a split second voltage peak turning your amp into over voltage protection..look under mechman thread for voltage spike this May be your problem. I still have not found a solution either
Tarball Posted March 21, 2013 Report Posted March 21, 2013 Did you fix this yet - and find out what caused it ? CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
Tarball Posted March 21, 2013 Report Posted March 21, 2013 I am running a mechman and kicker amp I have the same issue my amps turn off when leaving a stop light...its because the alt. May not be on at a low r.p.m. And when you accelerate the alt. Is turning on and throwing a split second voltage peak turning your amp into over voltage protection..look under mechman thread for voltage spike this May be your problem. I still have not found a solution either Sounds like a good place for a Cap CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
