Hertz_dont_it Posted March 23, 2013 Author Report Posted March 23, 2013 What is your RCA voltage? how do i test that? i tried putting the positive on there and nothing happened Current system:Front stage: Alpine type s 6.5No rear:Alpine type s 6.5headunit: alpineAmp: Jbl bp600.1 Sub: Alpine type x 12 dont know much about them. Found a "FLUX" Capacitor on ebay. If I add this to my system, can I really travel into the future? And how far into the future? That probably all depends on how I ground it though, right?Dude dont even waste your money on capacitors get a second car battery preferably a kinetik or stinger or any other car audio battery use the battery that is correct for your systems true rms wattage do some research on the net for this. Go to kinetiks website they explain how to pick a battery from thier site that fits your system.
SnowDrifter Posted March 23, 2013 Report Posted March 23, 2013 What is your RCA voltage? how do i test that? i tried putting the positive on there and nothing happened Set your DMM to AC, unplug the RCAs from your amp, play a tone, turn the volume up, put the (+) probe on the center pin and the (-) probe on the outer ring. ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Hertz_dont_it Posted March 23, 2013 Author Report Posted March 23, 2013 What is your RCA voltage? how do i test that? i tried putting the positive on there and nothing happened Set your DMM to AC, unplug the RCAs from your amp, play a tone, turn the volume up, put the (+) probe on the center pin and the (-) probe on the outer ring. ok i did that and it was sitting at like .3 but would jump up to .4 Current system:Front stage: Alpine type s 6.5No rear:Alpine type s 6.5headunit: alpineAmp: Jbl bp600.1 Sub: Alpine type x 12 dont know much about them. Found a "FLUX" Capacitor on ebay. If I add this to my system, can I really travel into the future? And how far into the future? That probably all depends on how I ground it though, right?Dude dont even waste your money on capacitors get a second car battery preferably a kinetik or stinger or any other car audio battery use the battery that is correct for your systems true rms wattage do some research on the net for this. Go to kinetiks website they explain how to pick a battery from thier site that fits your system.
SnowDrifter Posted March 23, 2013 Report Posted March 23, 2013 See if anyone near you has a DD-1 or an oscilloscope that can get you set up. That would be ideal, but if not: let me know and I'll walk you through the process http://www.stevemeadedesigns.com/board/topic/137758-smd-audio-tools-map/ ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
mnrookie Posted March 23, 2013 Report Posted March 23, 2013 Some decks have subwoofer output level, make sure that isnt all the way down.
Hertz_dont_it Posted March 23, 2013 Author Report Posted March 23, 2013 See if anyone near you has a DD-1 or an oscilloscope that can get you set up. That would be ideal, but if not: let me know and I'll walk you through the process http://www.stevemeadedesigns.com/board/topic/137758-smd-audio-tools-map/ there is no one close enough. each person is atleast an hour and a half away. if you could help id be thankful Current system:Front stage: Alpine type s 6.5No rear:Alpine type s 6.5headunit: alpineAmp: Jbl bp600.1 Sub: Alpine type x 12 dont know much about them. Found a "FLUX" Capacitor on ebay. If I add this to my system, can I really travel into the future? And how far into the future? That probably all depends on how I ground it though, right?Dude dont even waste your money on capacitors get a second car battery preferably a kinetik or stinger or any other car audio battery use the battery that is correct for your systems true rms wattage do some research on the net for this. Go to kinetiks website they explain how to pick a battery from thier site that fits your system.
deathcards Posted March 26, 2013 Report Posted March 26, 2013 what head unit? skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps
sbg Posted March 26, 2013 Report Posted March 26, 2013 sounds like u may out of phase (one sub moves more then the other) 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
