I have a Digital Designs X1 crossover which works great, but I'm concerned I might not be able to use the dd-1 with it. And I do not know enough about how to calculator crossover attenuation to figure it out myself :(
Issue is that the high-pass portion of my crossover can only cross as low as 490hz. It's a line driver too, so there's that to consider.
My concern is that 1 octave(1kHz) above the crossover frequency might not be high enough to avoid quieting down the signal, and possibly give a skewed reading. I could probably figure this out myself if I knew the equation for a crossover graph, but I'm spacing on how to figure it out right now lol
Things to note:
- This is a 24db/octave crossover
- It is a line driver too
- The lowest I can cross at is 480hz
Edited by SnowDrifter
Oh, and I'm not sure what type of filter it uses, whether it be Butterworth, Linkwitz-Riley, Chebyshev, or Bessel. So I'm in a bit of a tough spot there :(
An octave ABOVE the high-pass x-over frequency shouldn't be affected much, if at all.
I think :peepwall:
I know it's affected some, but I'm not sure if it's something so small that I can ignore it or not
I checked the stats on on DD's website but they don't have much other than what you stated (24dB/octave).
More than likely its Linkwitz-Riley, but for your question about before the cutoff frequency, it probably doesn't matter.
Here's a plot of a 24dB/oct slope (LR filters are -6dB at fc):
The fc is 80Hz. At an octave before (40Hz) you can see the slope just starts to drop.
I've seen the same effect on other filters (Butterworth).
At a full octave before the cutoff frequency, I wouldn't worry about any attenuation.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
