i was wondering where you get the thick rubber mounting feet for my amp because i want to mount it on my box but all i could find at lowes for skinny rubber washers
thanks for any help
97 exploder xlt2 18" obsidian audio daul 2 v2s1 sundown audio saz1500d at .5 ohm2 sets of alpine type r components1 MB quart onyx 125.4alpine cda-98871 mike singer 250 amp altxs d3400 in the backall kicker wiringBIG 3singer resonance killer sound deadner throughout
Go to a local hardware store. They will have 1 inch rubber corks (check my build log) and then just get 1 &1/2 inch flush mountedhead self tapping screws washers that fit the head of the cork. Mount amp normally. Less vibration, doesn't pierce box, and also elevates amp off the box for more cooling
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Just FYI they don't do anything for isolating the vibration from the amp ;) I only use them because they are a non-marring way to space my amp up off the box
I used faucet washers and just used 3 of them per foot and it works for me (they're beveled on one side so it was kinda hard to manage at first) theyre about 1/8" to 1/4" tall and they lift my amp up off the seat and ive already noticed the amp doesnt get as hot, kinda thinking of adding more in the near future
Feedback Thread: http://www.stevemeadedesigns.com/board/topic/152368-littlebuck1919s-feedback/#entry2177586
i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
6/18/82 - 4/17/12
R.I.P. to my sister Shana
Ill Have to find those rubber corks..I cut up a rubber fernco..< Obviously not the right way to do things..
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
Is that what you use^^^
Me? Yeah, it lifted my amp up off my seat like a quarter inch....get it as high off the mounting surface as u want, ill likely be using one or two more per mounting foot. I would recommend the beveled ones so that it helps add some more to ur gap :) plus for 6 (around here) is like $1.50 so they arent too expensive :)
6/18/82 - 4/17/12
  • Who's Online   0 Members, 0 Anonymous, 559 Guests (See full list)
