x91evo Posted March 29, 2013 Report Posted March 29, 2013 but of course dont forget you would need the electrical to back up your stuff at 1 ohm alot more than at 4 ohms
kirill007 Posted March 29, 2013 Report Posted March 29, 2013 So if I had a 1 ohm stable mono block at 1000rms and wired 2 subs to make 1 ohm they would both receve 1000rms and not 500eatch ? yup, its the resistance youre looking for not the amount of subs. 1 ohm is 1 ohm, the amp doesnt know the difference This is a problem these days, too much people want to answer these threads, often without knowing what they are talking about. x91Evo, are you actually sure about your response? To Thurston, If a amp is rated at 1000W at 1 ohm, it will only put out 1000W. So if you have 2 subs it will still put out a 1000W, that means both subs are getting 500W. (because 500W+500W=1000) So if you have 4 subs wired at 1 ohm, the amp would still put out 1kW, that means each sub is getting 250W each. A amp can't just produce 2000W because you connected 2 subs to it, that would mean if you attached 16 subs, the amp would produce 16kW of power. EDIT= x91Evo, please read a LOT more before answering any questions. If you are doubting about your answer, then don't post or use google/search to find the correct answer. Thinking is the root of all problems... You ALWAYS get what you pay for.
x91evo Posted March 29, 2013 Report Posted March 29, 2013 How does that make sense?1 ohm is 1 ohm.X amplifier is rated at 2000RMS @ 1 ohm.Wire 2 subwoofers together @ 1ohm, and how will they not both see the amplifier rating @ 1 ohm?
Ben Fultz Posted March 29, 2013 Report Posted March 29, 2013 Because the output of the amp (2000watts) is being divided or "shared" by 2 sub-woofers. So each is only seeing 1000 watts.
REVOofRustler Posted March 29, 2013 Report Posted March 29, 2013 How does that make sense? 1 ohm is 1 ohm. X amplifier is rated at 2000RMS @ 1 ohm. Wire 2 subwoofers together @ 1ohm, and how will they not both see the amplifier rating @ 1 ohm? The amp has to split power to both subs, meaning each sub would be receiving half of the power that the amp is rated to put out at 1 ohm. 2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant - Fi and Crescendo - Stock Bose System - http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota 136.4 Sealed @ 29hz 137.0 Drivers window open @ 26hz
kirill007 Posted March 29, 2013 Report Posted March 29, 2013 How does that make sense? 1 ohm is 1 ohm. X amplifier is rated at 2000RMS @ 1 ohm. Wire 2 subwoofers together @ 1ohm, and how will they not both see the amplifier rating @ 1 ohm? Just as I said, read up about electricity, there is a lot you can learn by using google. Electricity flows like water. If you have 2 equally sized holes in the hose, the water will come out with the same power(= volume(amps) x velocity(voltage)) If 1l of water flows through the beginning of the hose, then through those 2 equal holes .5l of water will come out per hole. There is only 1l availible, just because you add holes(= a load, resistance) the amount of water (=power) won't double. I hope this kind of explains it. Thinking is the root of all problems... You ALWAYS get what you pay for.
Chris Hammer Posted March 29, 2013 Report Posted March 29, 2013 Lol...1k amp give multiple subs all 1k.. Its divided...because it is a circuit. MY BUILD *****http://tinyurl.com/gmcbuild***** Vehicles 2005 GMC Canyon CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.) crf250r - Used to be race bike..now I just trail ride..practice at the track on it. CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg Sold to: Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585 Shower farts still piss me off.I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
x91evo Posted March 30, 2013 Report Posted March 30, 2013 Oh guess I didnt know as much as I thought sorry.Makes more sense considering each speaker is a load on the circuit.Still new to electronics sorray!
jouniorlord Posted March 31, 2013 Report Posted March 31, 2013 but of course dont forget you would need the electrical to back up your stuff at 1 ohm alot more than at 4 ohms mo powa mo betta
