Opinions on this 4th order for 4 sundown zv3 15"s.
So please explain to me why it wont fit like this.
When they are moved off center of eachother just enough to fit.
I've gotten a blowjob and picked up my iphone behind her back to see what email notification I got from smd before
If you stagger them... Suddenly each sub overlaps about 2 inches each... Subtract 4 inches from your "40" and suddenly thee is a 36 inch max.
Here is an example for you... Take cans of soda.... Line them up in a "flat wall" configuration with them exactly over each other and evenly spaced...now measure inches from the bottom of the round part on one can and continue to the top part of the can above that...now take those 4 cans and set the top two a bit over to the right and keep the bottom ones the same. You will find that because they are staggered they take up less space. Much less space.
Same idea with your wall. Off set them just a bit.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Only thing about a wall it's not guaranteed that four 18"s in a flat wall will be louder than smaller subs in a 4th order. I went to sbn this year and heard four zv3 18"s in a flat wall and it was no were near as loud as Jared's truck with the four zv3 15"s in a 4th order.
Clam shell, it's been mentioned a few times. Try it and see, if you don't like it, keep the shell sell all your subs and hope you are right about how magic a 4th is.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
OP. I think you should go with the 4th, I mean your friend jared its doing pretty good with it, and so is luckyishere (smd member) with 4 12"
as many others, plus if you go with ported wall an have success you will still wonder if the 4th could've been louder.
just my opinion
you should do what you want to do, after all its a hobby.
audio related merchandise (decals,banners,lanyards,hats,shirt,etc)
  • Who's Online   0 Members, 0 Anonymous, 1103 Guests (See full list)
