help with a burp tone
Hello im a little new and have learned alot on this site but i cant seem to find this answer anywhere.
When i tuned my system i tuned it with a -5db tone (because i listen to decaf and chopped music) and was wondering if i should use -5db tones for burping? or would it be safe to use say a -3db tone due to the short length of the burp?
Build log
http://www.stevemeadedesigns.com/board/topic/166486-alexs-02-intrepid-budget-build/
2 12" SKAR Audio VVXv2 d4 @ 1ohm
vvme qa-d1500
Pioneer Head unit deh-8400bh
2 Kenwood KFC-1693PS 3-Way 6.5"
2 stock sail speakers/tweeters (Infinity premium stock)
Polk Audio DB351 3.5" (upgraded from a factory 2.75" speaker or something weird like that dremeled to fit)
2 Sony Xplod XS-R6944 6" x 9" 4-Way's
Well, with a -3 you would not be clipping your subs, so if you use a -5 you should be still unclipped. Keyword: Should be. But you have factors also.
I think if you use a -3 you should be okay, if you use a -9, you would be clipping...If anyone else would chime in that would be great.
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
What do you mean here?
Alex, you could probably even use a 0db track for burp.
For info, a slight clip can increase score, clip to hard and you might decrease score while still making everything run hotter. Might be system dependant though.
That's what I've gathered.
You might just have to try for yourself.
ok thank you guys very much. i should be getting an oscope soon. so i will do some tests and see what works best for me.
I was just curious what others would do in a similar situation
Build log
vvme qa-d1500
Do you have a TermLab to play with as well?
no i dont i really wish i did but they are out of my price range and i havent found anyone in cincinnati with one
Build log
vvme qa-d1500
This is your biggest hurtle unless you know your freq already then I would suggest -3. Remember a test tone is not the same as music. You can clip your test tone since it doesn't vary, 1-2 sec of course
2011 Mitsubishi Outlander
Sony 712
Soundqubed HDS208
Alpine MRV-M500
Transmission line enclosure
Soundqubed wiring
Knu rca
XS Power battery
CNF terminals
Yeah thats what i figured so ill stick to -5 and play it by ear and a possible -3 (if only for a couple seconds) when i get an oscope .
i plan on going to a competition in the next couple months to see what kind of numbers i can put up from the trunk
Build log
vvme qa-d1500
  • Who's Online   2 Members, 0 Anonymous, 1511 Guests (See full list)
