gckless Posted May 28, 2014 Report Posted May 28, 2014 Knowledge-spreadin' bump. "Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand. My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/ High resolution photos: Gilbert Kless Photography
broncosean Posted July 19, 2014 Report Posted July 19, 2014 This is an amazing write up, I'm not experienced at all with anything more than basic circuitry, Ive taken a college physics two class that covered the ideology behind some of these basic components, capacitors, transformers, inductors, etc.But nothing very in depth on circuitry. I am confused, however, on one thing you wrote. "A capacitor acts like a short circuit at high frequencies. When paralleled into a circuit, it helps to eliminate (short-out) higher frequency noise. Also, the voltage across a capacitor can not instantaneously change, therefore its great for voltage stability (noise smoothing)." I thought that capacitors acted as a high pass filter, thus why are they are used on tweeters, so how do they eliminate higher frequency noise? And I also thought voltage could change instantaneously across a capacitor because their ability to discharge instantaneously? T 1994 Ford bronco Infininti kappa 4 channel driving a pair of reference 6.5s and a pair of 6x8 kappas downfiring console w/ a pair of image dynamic 8s on a memphis 250.1 1999 Honda Civic Si front doors- image dynamics ctx 6" coaxial with ID tweets Back deck- Image Dynamics ctx 6x9" coaxials Bass- PSI platform 1 12" in a 4th order tuned to 39hz Amps- CT sounds 60.4 highs and mids, Ampere Audio 1k bass Power- Big 3 upgrade, second juicebox 50ah battery, sky high 1/0, skyhigh battery terminals
Krakin Posted July 20, 2014 Report Posted July 20, 2014 This is an amazing write up, I'm not experienced at all with anything more than basic circuitry, Ive taken a college physics two class that covered the ideology behind some of these basic components, capacitors, transformers, inductors, etc.But nothing very in depth on circuitry. I am confused, however, on one thing you wrote. "A capacitor acts like a short circuit at high frequencies. When paralleled into a circuit, it helps to eliminate (short-out) higher frequency noise. Also, the voltage across a capacitor can not instantaneously change, therefore its great for voltage stability (noise smoothing)." I thought that capacitors acted as a high pass filter, thus why are they are used on tweeters, so how do they eliminate higher frequency noise? And I also thought voltage could change instantaneously across a capacitor because their ability to discharge instantaneously? T They do act as a high pass filter too, and when designing the input coupling capacitors you need to take into consideration that it will determine the overall low-frequency cutoff of the amplifier. I'm just going to post this from one of my amplifier design books. If I come across a better example, which I know I've seen somewhere, I'll post it up. Unfortunately, for reasons of noise and distortion, the feedback resistor R3 should be of a lower resistance value than a value like 50 kW. Bear in mind that the AC impedance feeding the LTP on the input side is quite low because the input coupling capacitor acts like a short circuit at audio frequencies. Ideally, the AC impedance on the feedback network side should also be low in order to minimize noise. There is thus a conflict between the DC and AC requirements at the input stage. It is also notable that when the feedback network impedance is reduced, the value of the electrolytic capacitor in the feedback shunt path must be increased accordingly Designing Audio Power Amplifiers By Bob Cordell http://www.amazon.com/Designing-Audio-Power-Amplifiers-Cordell/dp/007164024X Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener.
broncosean Posted July 24, 2014 Report Posted July 24, 2014 Almost that whole reply went over my head but thank you for the educated response, im trying to learn more about amplifiers and how they work as well as how all the individual components work in conjunction with one another, in my free time of course but i had really been looking for some literature and coming up short so thank you for the recommendation, I'll probably buy that book here shortly 1994 Ford bronco Infininti kappa 4 channel driving a pair of reference 6.5s and a pair of 6x8 kappas downfiring console w/ a pair of image dynamic 8s on a memphis 250.1 1999 Honda Civic Si front doors- image dynamics ctx 6" coaxial with ID tweets Back deck- Image Dynamics ctx 6x9" coaxials Bass- PSI platform 1 12" in a 4th order tuned to 39hz Amps- CT sounds 60.4 highs and mids, Ampere Audio 1k bass Power- Big 3 upgrade, second juicebox 50ah battery, sky high 1/0, skyhigh battery terminals
SIDE SHOW Posted July 24, 2014 Report Posted July 24, 2014 hi all, my PRSA500 Pioneer 2 channel amp has a heap of little fuses inside the board.... any idea what the story/idea is behind this?
broncosean Posted July 25, 2014 Report Posted July 25, 2014 hi all, my PRSA500 Pioneer 2 channel amp has a heap of little fuses inside the board.... any idea what the story/idea is behind this? could you post a pic so we know where these little fuses are on the board? 1994 Ford bronco Infininti kappa 4 channel driving a pair of reference 6.5s and a pair of 6x8 kappas downfiring console w/ a pair of image dynamic 8s on a memphis 250.1 1999 Honda Civic Si front doors- image dynamics ctx 6" coaxial with ID tweets Back deck- Image Dynamics ctx 6x9" coaxials Bass- PSI platform 1 12" in a 4th order tuned to 39hz Amps- CT sounds 60.4 highs and mids, Ampere Audio 1k bass Power- Big 3 upgrade, second juicebox 50ah battery, sky high 1/0, skyhigh battery terminals
SIDE SHOW Posted July 25, 2014 Report Posted July 25, 2014 http://magnitola.org/usiliteli/186430-pioneer-prs-a700-2.html this is the 4 channel version of the same amp, this is the guts of the prsa700. the fuses I am asking about are the 8 tiny yellow fuses. cant seem to post pics
SIDE SHOW Posted July 25, 2014 Report Posted July 25, 2014 i'm guessing they are there to protect the amp, when/if a speaker shorts or something.....
