What amp do you guys recommend?
naenae
I am running 2 10' CVRs 800 watts/RMS. What amp do you guys think i should run? Im kinda on a budget, so no 800$ amps.
If you guys could help it would be much appreciated :)
need budget a good 500-800rms amp will do like sundown,rf,kicker
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
Another option is look at 15-2k amp and run at 2-8ohm depending on amp
So when you deceid to upgrade your subs later you'll already have the power to feed them
The aq2200 is a good amp for 430 (on sale at moment) and will deliver 1k at 2ohm
I would suggest the audiopipe apsm 1500 for $125 or the apsm 2000 for $189, you still get the power but not pay too much
if I'm not mistaken didn't bigdwiz did an rms rating on the audiopipe 1500 it did 1000rms at 1ohm
2 sundown sd-2 d4
flex tech
box design by Joe X
Rf t500.1bdcp. Itll give you around 800 watts, idk the price though
2006 Ford Explorer
2 Team AA/Sundown 15s
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
With minimal clipping ive seen the apsm 1500 go 1200 at 1 ohm
  • Who's Online   0 Members, 0 Anonymous, 988 Guests (See full list)
