Typical noise from a sway bar link also. Have a look at them
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
wheel bearing in most cases, otherwise check ball joints, if it clunks only when you turn just like i had the problem the other day wit ha car at the shop, most likely ball joints or possibly cv shaft all depends...jack up the car wiggle tire left to right, if it has play ..wheelbearing
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
Audison Bit One processor
Jl-cl-rlc line driver
iPad in dash
Dual Irragi 320a alts
8 batcaps 4000's
Second Skin sound deadened
I'm not sure what it is.... I haven't had time to jack the car up yet. I did crawl under the best I could and everything seemed normal. I tried to wiggle everything and everything seemed pretty sturdy. That's probably because it was on the ground though.
So when I get it jacked up I will need to wiggle the tire. If it has some play, wheel bearing.
When I look at everything else, will a simple wiggle test and just a close look over suffice? I don't know what other things I could do to check everything.
Would hate to take it to a shop and get gouged by them.
Ok well I went out and jacked it up. Nothing would wiggle. Tire had no play in any direction. The only that would move was the axle that went into the wheel. It moved in and out, which I am assuming is normal. All the bushings seemed fine. I know the strut bushings are fine because I had them replaced this past summer. So I'm stumped.
As far as what?
Bushings are good. Nothing seem damaged. How else would I check the strut?
when you pushes down on the front of the car it made no noise ? IDK what else man...If the noise is still there i would have someone check it out..Get it reinspected 20bucks...If they say something is wrong ask for a 10 day and fix it yourself if your capable...
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
Yeah I already pushed down on it, thought I mentioned that in the op. Oh well I can't remember.
Anyways that noise is basically gone. Pisses me off how there will be a noise, then all of a sudden it is gone. This is the 3rd time, this has happened, each time with a different noise.
  • Who's Online   1 Member, 0 Anonymous, 1575 Guests (See full list)
