noob needs help with gains
Zach Martino
is a dd1 pretty easy to use ?
you hook it up to the amp and turn the gain knob up til the red light comes on...basically.
get a dd-1, they help a ton. And make sure everything is wired up correctly, like make sure you wired at the correct ohm.
93' Exploder
Deck:Pioneer 6400-bt
Front Stage: Crescendo PWX 8"s and Skar Audio VX1-ST per door
Amps: Sundown Audio SAZ-3500 v1 @.375 ohm daily, CT Sounds 125.2
Subwoofer: Two PSI Platform 2 18"s,Fully Loaded D1.5's
Enclosure: B Pillar Fourth Order, 3:1 ratio tuned at 46 (Designed by Low Hertz Box Designs)
Wire: All Sky High Car Audio Cable!
Alternator: Singer 250 amp Hairpin
Batteries: XS Power D975
Team Audio Connections
  • Who's Online   0 Members, 0 Anonymous, 731 Guests (See full list)
